Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1987 - 1996 F150 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Welcome to Ford-Trucks Forums!
Welcome to Ford-Trucks.com.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Ford-Trucks Forums community today!
Old 09-18-2014, 07:59 PM
Subaru Sti Subaru Sti is offline
Subaru Sti is starting off with a positive reputation.
86 ford truck no crank no start no power
Second selonoid in . Truck running fine 3rd replaced starter selonoid truck turned on. Let truck set for 30minutes turn truck off. After I turned truck off tried turning it on . This time truck selonoid stays open circuit removed negative wire from battery. ..... What its causing it to trip like that check all connection they clean and tight just replaced starter alternator battery and starter selenoid on this truck...... Help!!
Old 09-20-2014, 08:01 AM
mike Stansberry II mike Stansberry II is offline
mike Stansberry II is starting off with a positive reputation.
Sounds like the ignition switch is shorting out to the starter solenoid.
Similar Threads
86 ford truck xl no start no crank no power Subaru Sti 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 09-19-2014 12:03 PM
starter keeps turning after key is off 1SheldonW Super Duty & Heavy Duty 3 03-12-2013 09:12 PM
351m starter problem Unclejesse72 1973 - 1979 F-100 & Larger F-Series Trucks 12 03-04-2012 06:54 PM
78 F150 wont start quantalimo 1973 - 1979 F-100 & Larger F-Series Trucks 17 08-13-2007 09:06 PM
Starter issues on 85 Bronco Sirhcpordlaw Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 1 02-23-2005 08:01 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
