OD issues?
OD issues?
I have a 1997 F250HD, 5.8, auto trans w/OD 225k miles. Recently while in overdrive (above 50 mph) it intermittently has a light downshift and then right back into normal highway gear. Otherwise The trans shifts perfectly, smooth and quiet, no slipping at all. Could this be an overdrive issue? Thanks
Your transmission is 100% computer controlled, check for codes. The same computer for the engine controls the transmission.
Even though your truck is a 1997 F250HD model it could be OBD-I or OBD-II, Do you have a Data link inside the cab near the the middle of the dash (under the ash tray)?
Most '97 F-250s (and F-350s) were EEC-IV (often called OBD1?), but some (California trucks?) were OBD2. They were all one or the other, and both have the engine and auto trans completely controlled by the computer.
If it's OBD2 there will be a data port under the dash. If it's EEC-IV the data port is under the hood, probably near the left hood hinge.
on
it's something quick and free to inspect anyway;
https://www.ford-trucks.com/forums/1...s-harness.html
pay no attention to the 2 digit codes (yours will be 3) nor the early pack plug replacement (you'll need the proper year) nor the year range for the solenoid pack should you find a failed solenoid (again,you'd require the proper year for your truck.)
the basic fundamentals will help you.just use it as a guideline is the point.
antiquetvguy
05-13-2015 09:14 PM
jtyson8602
24
09-24-2013 12:09 PM
flooch
07-05-2004 12:50 AM
