m5od stuck in gear
Old 09-18-2014, 04:53 PM
90'F150's Avatar
90'F150
90'F150 is offline
m5od stuck in gear
so I had taken the shifter boot and rod off to get to the top plate of my trans because I wanted to add fluid without needing a pump . to get to the nut holding the shifter on I had to put the trans in reverse and after I was all done and bolted it back up started the truck and it wouldn't come out of gear. its got a brand new clutch pressure plate slave and master cylinder bled correctly and everything and now topped of with fluid but stuck this is my daily I have a second car to drive but choose not to drive it any ideas on how to fix this?? any help is appreciated thank you.
Lost cause
09-22-2015 09:04 AM
Sycostang67
General Automotive Discussion
07-23-2014 12:35 AM
ahaus
08-18-2010 09:22 AM
03KingRanch250
1983 - 2012 Ranger & B-Series
04-20-2008 09:26 PM
StangLX302
10-20-2007 01:30 AM
Quick Reply: m5od stuck in gear
