94 f150 tranny
94 f150 tranny
on my 94 f150 4x4 auto trans 5.0
my motor revving up seem not be shifting
I tried shifting manual seem to work when I get 60 I push in overdrive
it on my shifter was told it might be trans with 160xxx on it
I put in some lucas trans slipping oil in trans still no help
what can I check for ? tranny fluid is full
no leaks only motor revving up in rpm seem take long to shift
thanks. I hope its not transmission
A E4OD will do it also if you have a 4X4 with a 2 wheel filter in it.
Now you have to change the transmission fluid to get that junk out of the transmission. Never put anything in the transmission but Mercon V atf.
ok the bad and the good news
I tried code obd1 didn't find anything yes I did it right.
ok as I said yesterday I added some lucas oil for trans did not help
few months ago when I got the truck check eng light was on no code
got it from oriley check light went out.
then had trans flush didn't change filter .
since I added lucas trans oil for slipping.
more
so I took it in to tra said
transmission shop they drove it said its not trans
but the fan clutch so he called napa and it was not the same as oriley
guy said said I need the thin one. so the flush and change filter
he said filter look good so it cost me $225 for flush
and I put in new fan clutch it was job
now truck running great no more revving up
ty for advice all
ty for advice all
If the "check eng light was on" (MIL) you will have a code in CM unless you disconnected the battery.
You stopped after the electrical check (KOEO) and did not continue on to the CM codes. So no you did not do the codes right unless you disconnected the battery.
Disconnecting the battery will clear all of the CM codes except the memory error code.
If you truly have no codes in CM after the MIL was on then you have a bad PCM Computer unless you disconnected the battery.
mikeismadness
15
12-26-2010 08:35 AM
dustybumpers
05-03-2010 07:48 PM
northern hawk
04-17-2008 05:11 PM
