Missing and Stumbling @ WOT
Old 09-18-2014, 01:02 PM
BBslider001's Avatar
BBslider001
BBslider001 is offline
Well, guys, I am hitting the top of my learning curve since I have no idea what is going on and where to start with this issue. Short story really long....I have noticed since coming back from our Texas trip that Ruby very slightly bucked under WOT. When we replaced the alternator, it seemed to go away and I thought that maybe it had been related to lack of voltage for the injectors. (don't laugh) Well, yesterday we took a day trip up to the hills and it was very noticeable. I would ask it to get on it and it would have a lack of power, stumble and miss, and then when it would catch it was like "HOLD ON!!" because the power would really come up. I have done the rev test and it is perfect. I have a spare CPS I have not tried yet. I turned the TS chip back to stock and it seemed to not really make it any different. Now, if I don't ask it to push really hard, it's fine. No missing or stumbling occurs. It only does it when I really try to get on it. So, the list I have checked at this point:
Rev test (good to 3k RPM)
UCVH seem to be good (no melted wires, etc)
Voltage is good
Fuel filters pretty new since E-fuel conversion
No leaks anywhere that I can see
CPS from IH is only a year old, but I do have a spare from the Ford house
FP is good at idle, right at 65 PSI
Injectors are at 100k miles form what I was told, but who knows
MPG last tank was 17.2, so I'm not losing fuel
Any input on where else to look would be appreciated. I am still doing some searching to see what else to start picking apart. Thanks dudes!
Old 09-18-2014, 01:34 PM
glovemeister's Avatar
glovemeister
glovemeister is offline
Look to see if you have oil in the ICP plug?
Checked to make sure the tin nut is on the IPR?
Old 09-18-2014, 02:13 PM
DIYMechanic's Avatar
DIYMechanic
DIYMechanic is offline
Sounds like HPO to me. I'm betting ICP (the sensor, not the band - never cared much for the band) or IPR as well.
Old 09-18-2014, 02:14 PM
madMatador78's Avatar
madMatador78
madMatador78 is offline
^^ x2. That is odd indeed, Byron. Subscribing, now I'm curious! Maybe HPOP is getting tired??? I don't know, sorry I don't have more.
Old 09-18-2014, 02:56 PM
427 fordman's Avatar
427 fordman
427 fordman is online now
Unplug the icp and try it Byron.
Old 09-18-2014, 03:01 PM
fordman67's Avatar
fordman67
fordman67 is offline
Can you look at hop to see if the pressure is falling off? May be time for the next mod lol
Edit: sheesh I late
Old 09-18-2014, 03:30 PM
Hussler's Avatar
Hussler
Hussler is offline
Bet the fuel pressure is dropping when getting on it hard. Fuel filters might need replacing even though they are somewhat new. Inexpensive fix if that is the issue.
Old 09-18-2014, 07:54 PM
samthelion's Avatar
samthelion
samthelion is offline
Question Question
Is there a glossary somewhere for all these acronyms?
I would really like to know what you are talking about since I have the same problems with my truck.
Old 09-18-2014, 08:30 PM
oldbird1965's Avatar
oldbird1965
oldbird1965 is offline
Unplug the map sensor and see what happens.
I would bet hpop though.
Old 09-18-2014, 09:26 PM
BBslider001
Tin nut is good and tight. I am going to pull the ICP plug in the morning. I have just been slammed today. thanks for the input!
I am hoping Nate. I'll check it in the morning. Got dark on me out here in the west.
Thanks Darin. Gonna do it in the morning....before I start it, right?
Edit: sheesh I late
Ha Aaron...already spending my money for me! My HPOP seems to be good as far as PSI. It stays solid through pulling even when it stumbles. I am able to monitor through the Edge! Dumba$$ me did not even know that until Travis pointed it out and set the perimeter for me. My ICP PSI is at 2400-2500 at WOT and the IPR duty cycle is at 34%. Travis said those were good number for my mostly stock setup. It only varies about 50 psi no matter what is going on whether pulling hard or just normal acceleration.
Thanks Jim! I kinda wondered. I have put about 10k miles on it since the conversion. 3700 of those miles are from my recent trip to Texas and back. I drained the water before my trip and it didn't seem to have any, but wow the dirt! I am going to replace those tomorrow along with a leaky hose clamp.
I'll do this too. Do I unplug it along with the ICP or just do one at a time during test runs? Make sense? I am hoping not HPOP just yet. If it is though, I am not sure if I'll go with a T500 or an SD upgrade. I'll need to either way with new injectors that are planned for the early Spring.
Ya'll, thanks for your help! I'll get a report back in the morning when I go through it all.
Sorry for the delayed response. Its been one of those days where you lose your job, yell at your District manager, as well as your GM. Yes, in that order. I have a few things lined up though thank the Lord. I just hope it doesn't put a damper on truck plans!
Old 09-18-2014, 11:07 PM
fordman67's Avatar
fordman67
Aww crap..really? Loose job...man I hope it all works out!at least you have Friday off and you like to surf..now go clear your head!
Old 09-19-2014, 12:13 AM
BBslider001
Ya read my mind Aaron! LOL
Old 09-19-2014, 12:18 AM
fordman67's Avatar
fordman67
I say if you are gonna fire me...do it on Monday ..I'll take my time off!
Old 09-19-2014, 05:33 AM
427 fordman
Byron, unplug the icp then start it and drive it, see what happens. Same with the map, just do them seperately. Both times will cel, but see how it runs.
Sucks about the job man..
Old 09-19-2014, 05:47 AM
DZL JIM's Avatar
DZL JIM
DZL JIM is offline
PREMIUM SPONSOR
Kind of sounds to me like an injector not happy with the high ICP called for on a hard throttle run.
Unplugging the ICP sensor will default to around 725 psi and if that makes an effect on your issue (I'm sure it'll be a turd to drive) it could be either the sensor or the issue I described.
One way to help is to make or borrow a cut-out box for the injectors and when it starts to stumble shut the injectors one at a time till you find one not making a difference. Replace that injector and retest.
We can usually see these issues on the flow bench, but not always. It seems the injectors that have oil psi issues loose around 2200 psi or higher and simply studder and not flow at high rpm, high oil psi.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Quick Reply: Missing and Stumbling @ WOT
