1 melted ucvh pigtail
Truck starts like its running on 4 cylinders, CEL is on im getting p1316 code, nothing else.
I inspected my harness and only one pigtail was melted out of the four. From what I've read glowplugs fail and short the harness out.
So my question, do I replace all my glowplugs as its probably time and to prevent further problems, as well with all new ucvh pigtails as preventive matenince.
Or do I just replace the one pigtail and 4 of the glowplugs in the affected valve cover?
If it were me, I would replace all 8. Chances are if you have some bad ones, the others aren't real far behind. About the time you get it back together, some on the other side will start to fail, at least that's how it works for me most of the time.
As for the harnesses, obviously replace the burnt one, but if the rest is in good shape, and there isn't any oil inside the connectors, you could re-use them. OEM ones are a little spendy, but worth it in my opinion, Riffraff is where I got mine. Though some here have run the Dorman ones with out any issues.
X2. Replace all GPs and at a minimum the bad harnesses. If you decide to replace all the harnesses research converting to SD style harnesses. My experience with the Dorman harnesses was not good.
If the IDM detects a short, it will shut an entire bank down. So that explains why it sounded like it was only running on four cylinders.
We strongly suggest OEM, whether you purchase from us or locally, because the are reliable and last unlike the overseas knockoffs. We actually would make more on the Dorman, but we won't run them on our own trucks so why sell them, right?
Under Valve Cover Harness 94.5-97 - Riffraff Diesel Performance
I was definatly glad I didn't cheap out, I only had one side that was bad, and it wasn't even that bad, but I had the money, and wanted to do it right so it got 4 new harnesses and 2 new gaskets.
And like Phil said, you could convert to the SD gaskets (only 1 harness per side insted of 2), I think it ends up being cheaper when its all said and done, but theres some soldering and splicing involved, if your up for that sort of thing.
The Super Duty ones are the way to go, although it is more work to get them setup. They look much cleaner, and have better pin/wire size. Also, the UVCH design Dorman has is awesome these days. They are one piece and has no internal connector that is known to come apart.
I just used extra electrical shielding on my wires when I did it and knock on wood so far has been great.
Here is a list of what you need to convert.
2 - Valve Cover Gasket Connector Pigtail 99-03 - Riffraff Diesel Performance
2 - Valve Cover Gasket 99-03 - Riffraff Diesel Performance
2 - Under Valve Cover Harness 99-03 - Riffraff Diesel Performance
[/QUOTE]
IIRC through riffraff its about 100 bucks cheaper to go the SD route with one connector.
As for other maintenance, how are your glow plugs?
[/QUOTE]
Thank you for the schematic, but I still would like a write up to allow me to be comfortable w doing this mod., ive never even used a soldering gun before. I havent found any write ups conataining info to convert.
My gp's are fine other than one I think. I havent ohmed anything out, but on the one melted pigtail, only one of five of the ports is melted. Thus im assumming my other gp's are ok, probaly not the best method of determining a problem. But if my valve covers are coming off all gp's are coming out.
[/QUOTE]
^ thanks again for all your help, I will definitely rep ya.
Looks like im converting, ill order everything tommorow. Thank you riff raff for posting links to what I need.
Ill pick up some gp's to keep me occupied over the weekend. This will be a first time project as well. I will be using Motocraft gp's unless there is better out there, but these have lasted for 17 years
