Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1987 - 1996 F150 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Welcome to Ford-Trucks Forums!
Welcome to Ford-Trucks.com.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Ford-Trucks Forums community today!
Old 09-17-2014, 11:49 PM
'90-f150-302-5spd '90-f150-302-5spd is offline
'90-f150-302-5spd is starting off with a positive reputation.
Almost done with 351W swap, need advice
Hey,
I've been working on a 5.0L to 5.8L and Mazda 5 speed to ZF 5 speed swap for the past few months. I got the engine and trans out of a 1989 F-250 and they're going into a 1990 f-150.
After a longer than expected wait and price sheet from the machine shop I finally got the engine back for the full build-up and have it just about buttoned up.
I have a few questions to ask ya'll.
My wiring harness from the 5.0L Is in rough shape and the 5.8L was cut off when the engine was pulled. I went to the salvage yard and found the only good harnesses were the ones with the newer large 1-piece square connector to the body while my truck has the older style with the 4-separate connectors. Is there any way to re-pin or solder the old style onto the new harness (so long as the donor harness is not MAF)?
Also, the new throttle body has both of the connection points for the EVAP system (one between both intakes on outboard side and the two on the inboard side that connect via Y). Does it really matter which one I use as long as I plug the other?
Finally, I am eliminating the smog pump but I am keeping the EGR system. I have a set of Hedman full length headers on their way from summit. They do not have the EGR attachment bung welded on them. Would it be advisable to just find where the EGR tube hangs down onto the header from the valve and just weld the appropriate pipe coming off of it?
On the ZF 5-speed, is it possible to just go ahead and replace the input and output shaft seals before getting it in just to find out the seals leak? Or does that involve disassembling the transmission?
Thank You for any insight you may have.
Here's whats going in.
Click the image to open in full size.
Old 09-18-2014, 09:13 AM
Conanski's Avatar
Conanski Conanski is offline
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
Quote:
Yes, but you will have to trace and label all wires in both harnesses to know where to put them, wiring diagrams may not be a lot of help.
No
Yes, and the female end of another EGR tube works great as the weld on fitting.
That is a good idea but I don't know what is involved in doing it.
__________________
Paul (Conan) O'Brien
1990 5.0HO AOD XLT X-Cab F150 3.55LS, 1994 3.0L 5-sp x-cab Ranger 3.45, 2004 3.0L 5-sp X-cab Ranger Edge 4.10, 2004 2.5L 5-spd Subaru Legacy
1996 Kawasaki ZX11D, 2004 Honda 599, 2008 Kawasaki KLR650
Old 09-18-2014, 05:53 PM
Shadow944795's Avatar
Shadow944795 Shadow944795 is online now
Shadow944795 is starting off with a positive reputation.
Subing to this, I have plans to do a swap like this myself and wanna see your end results, I'm hoping to get it done by no later than the end of this year if I can help it.
__________________
"The trouble with quotes on the internet is that it's difficult to determine whether or not they are genuine." - Abraham Lincoln
The Blue Goose aka My old Ford: 1990 Ford F-150 with a 302 that likes to see 5 grand often.
New to me car, The cancer patient - 1995 Nissan sentra GXE that's full of rust holes
Old 09-18-2014, 10:44 PM
Thanks for the insight Conaski. I'll probably steer away from the harness re-pin. I gotta do some looking around about the ZF seals.
I also threw in the Crane CompuCam 444232. Do you know what distributor gear type is recommended? I cant figure out what the cam is made from and I know that different cam materials require different dizzy gear materials for proper wear.
Thanks again
Old 10-01-2014, 06:30 PM
Well, I got the 5.8 and zf dropped in today. My next step is to start looking at exhaust setups. I also got the bung welded up on the headers for the egr. That idea to use another egr tube worked great.
If going with duals, is 2.25" from collectors back alright? Or if going with a single, what size do you recommend from collectors to Y, then from Y back?
Thinking of using dynomax super turbo or dynomax VT muffler(s). Any recommendations on a quite muffler with good tone? No cats by the way.
Thank you
Old 10-01-2014, 07:14 PM
Conanski's Avatar
That flat tappet cam needs a cast iron distributor gear, be sure to follow the breakin procedure to the letter and always add a ZDDP additive at every oil change.
__________________
Old 10-02-2014, 12:42 AM
Thanks for the reply, I forgot to mention i figured that out.
As far as the exhaust goes, I would like to go with a single setup, but I've found a couple "header-back dual exhaust" setups. But they're 2.25" dia. I know that there's a good chance they wont just line up with the headers, but they oughta get them close enough that it'll be much easier to modify that system than build a custom Y-pipe from scratch.
As far as performance goes, the 5.8l got the cam, heddman long tubes and a K&N-style custom filter setup. I plan to use this truck as a truck and not something I expect to try and race every guy that pulls up next to me at a light. So if it loses power on the top end, but has some good low torque, I'll be happy.
Thanks again
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Similar Threads
Six Door Centurion F350 Powerstroke Project BrettMavriK 1987 - 1996 F150 & Larger F-Series Trucks 95 03-28-2014 10:16 AM
2000 8ft bed to 2011 8ft bed upgrade tail light wiring issue pzp107 Super Duty & Heavy Duty 6 05-23-2013 08:19 PM
Wiring help! deankelly Ranger & B-Series 0 01-23-2013 08:31 PM
engine code questions firewood truck 1987 - 1996 F150 & Larger F-Series Trucks 46 05-31-2012 08:41 PM
Engine wiring harness attachment ? radramrod2 1987 - 1996 F150 & Larger F-Series Trucks 1 01-31-2005 05:01 PM
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
vbulletin Admin Backup
