Installing head studs this weekend-Finished!!
Well, my head gaskets are perfectly OK! No puking or losing coolant but I plan on doing some upgrades to the truck and I want to get this out of the way.
Here's the catch, I will be doing the studs one at a time without removing the heads. I have done tons and tons of reading and it seems everyone who has done it hasn't had any issues with it. Unless the gaskets are already blown or head issues.
I will remove the HVAC box on the pass side and on the driver side I will remove the intake and degas bottle.
Since I'll have the valve covers off if not done-I will be doing the upgraded stand pipes and dummy plugs-will try to snap some pics for you guys.
I got the studs for $413 shipped from XDP!
Well, my head gaskets are perfectly OK! No puking or losing coolant but I plan on doing some upgrades to the truck and I want to get this out of the way. Here's the catch, I will be doing the studs one at a time without removing the heads. I have done tons and tons of reading and it seems everyone who has done it hasn't had any issues with it. Unless the gaskets are already blown or head issues. I will remove the HVAC box on the pass side and on the driver side I will remove the intake and degas bottle. Since I'll have the valve covers off if not done-I will be doing the upgraded stand pipes and dummy plugs-will try to snap some pics for you guys. I got the studs for $413 shipped from XDP!
Keep us posted sir!
I did not remove anything, except the driver side motor mount, to get the last three bolts out of the passenger side head. Jack the front of the engine on the driver's side. Remove the driver side motor mount. Let the exhaust manifold rest on the frame. Remove the nuts holding the passenger side motor mount. Locate a jack just behind the motor and jack the tranny and motor over until the bolts clear. It works well. Good Luck!
Ed
Yes. I shopped around like crazy and couldn't find them any cheaper.
I am currently running the SRL tune from gear heads but I am really looking to turn it up more. I'd rather do the studs now then worry about it later. More of a piece of mind.
As far as the turbo feed and drain tube, there are updates to both you should consider. Trucks built after January 2006 came from the factory with the updated turbo feed and drain tubes from what I remember.
Fwiw,,, I did a truck last week that the owner tried the one bolt at a time "trick". Didn't work so well for him. I personally would rather gamble at the casino.
The old arp lube called for 250 ft lbs. That lube wouldn't allow the torque to be consistent,, thus the higher torque value. The "ultra torque" lube arp has out now has iirc a 95% likely hood of hitting the value on the first sequence. I do final torque to 215 with ultra torque. I also lube the studs first,, then both sides of the washer while installing,, then the base of the nut n the threads just before threading them on. You will know if you did not lube enough if they "pop" while tightening. No pops here,,, EVER.
