Welding rocker panels
I'm gettin ready to do some welding on the rocker panels on my 2001 f150 supercrew. Just making sure I just have to disconnect ground at battery.
Never had a problem before but my neighbor blew both his airbags attempting it on his chevy. He said he had battery disconnected, wasn't specific as to which cable, and was grounding off the door strike which could have something to do with the airbags deploying? I've done it on a 02 chevy with no problems
it all boils down to this, electricity will take the shortest easiest path, IE least resistance. if you gournd on one end of the truck and weld on th other, you will have issues of one sort or another. grounding with in a foot on the same piece of steel that you are welding on will greatly reduce this issue, but leaves the chance for ground loops to possbily exist, this is why it is reccomended that you unhook the gorund from the battery.
I'll take some pics tomorrow. These were patches also, but almost 7 feet long. There was not much left to grind off, just enough to get into the good stuff. They start just under the plastic guard and go all the way under. I picked up 2 18ga 10' sections cut at 6" each. I used the scraps for extra support and some rocker repair. My running boards did not make it through the removal procedure.
totalrecall
1997-2006 Expedition & Navigator
02-09-2009 05:30 PM
