Diagnosis help after injector install
#32
#33
No compression test done.
I am still getting the #8 contribution fault after the chip came back yes. I have deleted the fault. About 250-300 miles, I haven't been driving it much. I don't like driving the way it is. I'm probably being overly cautious but I don't like things that aren't 100%. Looks like I'll be borrowing a truck for this coming weekend. I need to tow my Jeep to a rock crawling competition, and I don't trust towing with it. Again probably being overly cautious.
#34
#36
#38
#39
#42
And just some more info for camparison:
They way I learned it 10 years ago, On a CCT anything under 4% is fine. It's been a long time since I messed with CCT but if u like I can run them on both my 7.3L's so you can have a comparison.
On my Excursion with new 160/80 injectors from FFD I only have 4 or 5 at zero. The rest have some percent under 3 or so. Now having said that, if I change programs to one with a tad higher idle, more go towards zero. If I change it to a high idle program - they all go to zero.
On my F-250 with 8 year old Remans I see #4 with readings around 3-4%, #8 occasionally goes higher than that. It's been that way for a long time.
#44
Ok, It has been a while. The chip FFD sent me to try made no difference in the idle, or hesitation. It did quite down the injectors a fair amount though. I have spoken with Ryan at FFD(a 40min phone call). Turns my local dealer was not getting him all the info I was giving them about what all I have done to diag. the issues. He was very helpful and took the time to come up with a solution with me. I do feel it is just the #8 injector causing the problems, but I wanted new ones for peace of mind. So I am sending the remans back and getting the %30 nozzles swapped over to a set of new AC's. At a cost to me of course, but a fair price IMO.
After the new injectors are in, then it's time for some more tuning changes. There are some things I would like changed, especially after going through this process and learning a lot. I feel some of the noise difference between tunes is injection timing. The ICP and pulse width is very similar with both tunes, and stock. I can't see injection timing data with what I have. Also Jody told me there is no change in tuning for stage one(160cc/stock nozzles), and stage 1.5(160cc/%30 nozzles) This seems odd to me, and Ryan at FFD suggested the nozzle change should be accounted of in tuning.
