Oil Pressure guage????
ok I recently did an egr delete kit aswell studded the heads trucks seems to work fine I had some issues with the stock gauges but now they work. Yesturday and early this morning when I started the truck it said check guage the oil pressure was all the way down when I gave it some gas it went right back to normal any suggestions why this maybe happening and or solutions???
The "OIL PRESSURE" gauge in an over grown idiot light.
When the pressure at the sensor(switch) reaches about 7PSI
the gauge will jump to center. There is no true pressure reading
other than you have at least the 7psi.
The only to get a real reading that you can count on it add a gauge.
You might want to check the harness to see if you have a bad wire.
Sean
Sean
thefarelaneman
11-11-2006 07:37 PM
