Confused
Old 09-17-2014, 01:34 PM
ShoneyBoy's Avatar
ShoneyBoy
ShoneyBoy is offline
Originally Posted by coreyallan01
Just for grins, have your tried putting the truck back to stock for trouble shooting purposes?
I done that just a few minutes ago and it ran like crap,bucking and jumping cutting off,could that lead me to PCM
Old 09-17-2014, 01:39 PM
coreyallan01's Avatar
coreyallan01
coreyallan01 is offline
From what I've read the bucking jumping is a trait of a bad TPS at times, tho I'm not an expert in the field.. I forget if Superchips manipulates the TPS but you could call them real quick and ask a tech..
Old 09-17-2014, 02:57 PM
DIYMechanic's Avatar
DIYMechanic
DIYMechanic is offline
If you've had that many CPSs in this truck while trying to overcome this issue I'd say we can probably rule that out as a possible cause.
Is the Superchip you have an old school chip that goes on the PCM or is it a "programmer" that plugs into the OBD port? If it is a chip on the PCM, remove it altogether and see what happens. If it is a "programmer" I have a sinking feeling that you're going to be in the market for a PCM to solve this issue.
The other thing you can check is to pull the IDM out and give it the shake test, listening for water inside.
Old 09-17-2014, 03:11 PM
coreyallan01
I'm assuming he has a 1705 tuner.. You don't think it could b a TPS?
Old 09-17-2014, 03:51 PM
ShoneyBoy's Avatar
ShoneyBoy
I am going to put a TPS on it this afternoon,if that doesn't fix it I am going to have the PCM reprogrammed tomorrow,as finding one is almost impossible
Old 09-17-2014, 05:43 PM
427 fordman's Avatar
427 fordman
427 fordman is offline
I know you said you checked the cam sensor wires, but I'd double and triple check them too.
Old 09-18-2014, 06:06 AM
DIYMechanic
^^2x on the CPS wires.
The TPS or IVS could cause bucking but there is nothing there that will cause the truck to die. If the TPS sensor reads out of range or the IVS reads closed when it shoul dbe open, you get a CEL and the engine just idles.
I think you'll find that the TPS won't change much. I don't blame you for having the PCM reflashed as that's a pretty decent idea in my opinion. I'd pull the IDM and check it for water too while you're at it.
camodown
17
08-19-2010 03:51 PM
bumper05
1999 to 2016 Super Duty
02-09-2009 06:34 PM
F250_
30
02-01-2009 08:39 PM
ftowelding
11-01-2008 08:39 AM
davidsenna
01-12-2007 10:22 AM
Quick Reply: Confused
