1948 F-3 V8 6volt vs 8volt battery
My '48 F-3 V-8 with the original 6 volt system starts and runs fine. The battery needs replacing and "some" have said go to an 8 volt, no problems and it will turn the starter faster. If I've had no problems with the 6 volt are there advantages/disadvantages in going to an 8 volt? thanks
An 8 volt battery is usually added to mask another problem and brings problems of its own. You said it " My '48 F-3 V-8 with the original 6 volt system starts and runs fine."
Why mess with something that works good. A six volt system works very well when it is right.
And with only six posts, welcome to the forum.
I not so sure a 6 volt gen will put out enough ever to charge a 8.4 volt battery
Each cell of a battery is 2.1 volts
a 6 volt battery has 3 cells = 6.3 volts
a 8 volt battery has 4 cells = 8.4 volts
a 12 volt battery has 6 cells=12.6 volts
If a 12 volt system is supposed to charge 13.2-14.8 volts then a 6 volt system should be half that or 6.6-7.4 volts
If you had an 8 volt battery your output would need to be around 9-10 volts and I'm not sure a 6 volt gen will put out enough to cover the 8 volt batt needs.
You can make a generator or alternator put out any voltage you need (within limits) by adjusting the regulator. When you go 8v, you have to adjust the regulator to account for it or it will soon be a 6v battery .
I suppose 8v is just the ticket on a tractor where you might have a headlight, but nothing else electrical to run. On a car or truck it just makes no sense IMO.
fordf348
15
07-27-2015 03:01 PM
