Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty & Heavy Duty
Sign in using an external account
Register Forgot Password?
Super Duty & Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Welcome to Ford-Trucks Forums!
Welcome to Ford-Trucks.com.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Ford-Trucks Forums community today!
Old 09-17-2014, 07:05 AM
David7.3's Avatar
David7.3 David7.3 is offline
David7.3 has a good reputation on FTE.David7.3 has a good reputation on FTE.David7.3 has a good reputation on FTE.
2011 F-250 superduty stiff steering
Howdy guy's I got a 2011 250 SD 6.2, I have what feels like a catch in the steering, on center, when you turn the wheel feels like it just gives and stay's there, either way you turn, Checked front end, ball joints tie rods ect, the hubs are unlocked, feels like when the u-joint on the steering shaft goes bad and you get that bind. But this truck doesn't have them anymore, just a rag joint at the box. It only binds at center, and wont return, took steering stabilizer off and road tested same thing, air in tires good all the way around, has about 58,000 miles on it. Any body run into this problem suggestions would be greatly appreciated.
__________________
99 F-350 7.3 PSD 6" superlift springs, 35 toyo load E tires, true trac front, detroit locker rear, 140 gallons fuel, Desiel-site coolant filter, 6.0 trans cooler, BDS trans, Banks billet converter, Bank trans command, Banks turbo housing, wicked II wheel, big head waste gate, Power elbow, EBCV removed, diesel-o-rings in fuel bowl. 203 t-stat,TS Performance tuner, True 4" exhaust turbo back, More to Come when the funds come.
Old 09-17-2014, 07:33 PM
redford's Avatar
redford redford is offline
redford has a spectacular reputation.redford has a spectacular reputation.redford has a spectacular reputation.redford has a spectacular reputation.redford has a spectacular reputation.redford has a spectacular reputation.redford has a spectacular reputation.redford has a spectacular reputation.redford has a spectacular reputation.redford has a spectacular reputation.redford has a spectacular reputation.
At about 60,000 miles my ball joints were in need of replacement. Have your front end inspected at a reputable suspension shop.
__________________
2007 F-250 Super Cab Short Bed 4x4 XLT Sport Package 5.4L 3.73LS Tow Command
Stuart
Retired Master Sergeant
FTE Guidelines
Old 09-18-2014, 05:24 AM
David7.3's Avatar
I put it up on the rack and jacked up the front end, put a 4 foot pry bar under the tires and there was no play what so ever, I have a grease needle and was able to lube them, just to be on the safe side, and it's also a come and go problem it seems every 2-3 weeks we have have this problem, and when it does it if you shut off the truck and restart it the problem goes away. Then after 15 minutes it's back, you dont lose the power assist but it just binds on center, there was a TSB on contamination of the steering fluid and they say to replace the pump and resevar and flush the system. I dont know!
__________________
Old 09-18-2014, 05:28 AM
redford's Avatar
Here is your TSB list for 2011.
Fulltext TSBs | Ford Trucks
__________________
Stuart
FTE Guidelines
Old 09-18-2014, 05:39 AM
David7.3's Avatar
Yes Stew, thanks thats were I got the contamination info from, just hate to put that money in there when it may be something else.
__________________
Old 09-18-2014, 06:31 AM
je5 je5 is offline
je5 is starting off with a positive reputation.
Remove tie rod ends from steering knuckles and move the knuckles back and forth by hand noting the smoothness. Ball joints and 4WD axle joints will cause this problem soon and often. Your steering box sounds like it is the culprit though. Let us know.
Old 09-18-2014, 12:31 PM
droldsmorland's Avatar
droldsmorland droldsmorland is offline
droldsmorland is gaining momentum as a positive member of FTE.
Another member had a similar problem a while back. It was his front outer axle ujoints. They were frozen. Like the last post said take it apart and find the bind. Rotate the front wheels while you move the knuckles left & right. Then go at the box if this all checks out ok.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Similar Threads
steering issues forkhorn 6.0L Power Stroke Diesel 2 09-01-2014 11:11 PM
Has anyone had this steering problem? KC Steve Super Duty & Heavy Duty 5 08-25-2013 07:57 AM
Steering Bind Skoozo 1973 - 1979 F-100 & Larger F-Series Trucks 8 05-24-2003 08:44 PM
Steering problem VFox 1966 - 1977 Early Broncos 2 07-25-2002 11:52 AM
Steering binds kurt russell 1973 - 1979 F-100 & Larger F-Series Trucks 4 10-08-1999 11:41 AM
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
vbulletin Admin Backup
