ABS pumping without brakeing in mud?
I've noticed that my 06 f350 will pump the ABS when pulling in muddy spots, mostly in 4x4? It will even start to cook the pads after a bit of spinning.
I'm not doing any serious off-road stuff, just trying to pull random farm equipment/trailers. Do these trucks have some sort of traction control that I don't know about or dose my ABS think I have my foot on the brake all the time?
Pulled a pair of wagons out of a really muddy field today and the ABS pump was going like crazy, it actually seemed to help with keeping the slipping tires held back. I'm still trying to figure out if there's some sort of traction control or if there's something wrong with my truck? It only does it when one tire really gets to digging in 2wd or 4wd?
I think there's something other than the brake light switch that actually tells the truck that you're applying the brakes. I say this because if I have the cruise control set and just barely tap the brake pedal, the brake lights come on but the cruise control doesn't cancel. In order to cancel the cruise control, I have to actually press on the pedal and apply the brakes a bit.
Sent from my HTC ONE using IB AutoGroup
It does act like traction control but it isn't very aggressive compared to anything I've driven with T/C, I owned this truck for two years before I noticed. There isn't any thing in the owners manual that I can find that suggests that there is T/C and it doesn't have an off button.
It isn't what I would consider a problem but is more something my truck does and I can't explain and I am a curious guy.
