351m t0 400 build help?
I'd like to turn my 351m to a 400, and have read a lot of the articles on here, but I am a working man with a family and don't have $5,000 to $7000 to invest in a motor that is a daily driver. Is there a less expensive route, say around $2000 to $2500, that I could put into a decent motor build?
400 crank. TMI pistons for 9ish compression. RV cam with appropriate springs.
Run it with your stock manifolds and 2bbl intake and see how you like it.
All other rebuild costs still apply, especially making sure the heads are in good shape, and a rebore if needed, plus new bearings, oil pump etc.
Some mod the oil passages with a kit - I did not in my build. I would ask Tim Meyer what he thinks and go with his advice. Ask him at the same time you buy his pistons.
Thanks for the help. The reason for wanting to rebuild into a 400, is when I bought it it ran a little rough, it blew a little blue smoke and would stall out as well as had a vibration when idling or running at any throttle opening. I figured it had a bad valve or valves so I did a compression test tonight. My numbers were 1 120, 2 116, 3 120, 4 131, 5 120, 6 134, 7 130, and 8 127. definitely ready for a look inside!
Jacob Federow
03-15-2017 04:43 PM
BDawg171
11-03-2010 05:27 PM
lotty1525
06-01-2002 09:05 PM
