will this engine swap?
on
If they are both auto, yes it will bolt right up. The auto and manual transmissions use a different size flex plate. They should have identical intakes, but the heads are different. the 94 will have F3TE heads, and the 92 would have E7TE heads, assuming they are not aftermarket.
on
going into the 94 f350. the current engine runs, but has a really bad knock. found an engine that the wiring harness is fubar on, so we hope to swap.
on
