shackle flip and add a leaf, 4 inches?
To make things easier for you, you do not have to quote me, unless your answer to a question or a question you have is not the next in line.
Swap to 33's or 35's and no lift needed, wala done. Life is simple like that sometimes.
Hang in there figuring out the web site, it took me a while and I still do not have it all under control. lol
Computers..PITA.
Computers..PITA.
To the OP
I guarantee you nobody is laughing at this point .. If you can't even get how to start a single thread after it was explained to you .. You have no chance of getting this lift right .. Show some willingness to learn and read what people have taken the time to post on your behalf and stop wasting peoples time ..
william16339 stay focused on the task at hand, getting your lift figured out. The more I think about it swapping to 33's or 35's would be easier in the short run of it.
My 77.5 has 33's and add-a leaf, the 78 has 4" and 35's, 79 had 6" and 35's, but room for 36-38's .
I think the 37's you have now fill the fenderwell just fine, so unless you are going to be major league off roading that truck, stay where you are at.
Figure out the trucks day to day use or weekend use level and build to suite that need.
The amount of rear lift can be controlled by the placement of the rear shackle, meaning it not just a flip and go. But a flip and figure where to mount to match the front.
Clear enough now?
There are so many variables that come into play in setting up the rear shackle flip, that getting the front set with a lift that is a bolt on set amount of known lift, is what should be done 1st, IMO and others.
Clear enough now?
Clear enough now?
Do the front first then you won't have to do the rear twice.
Once you reply to a thread, it goes in your saved or "user subscriptions" file list. Access that list from YOUR "User CP". It is located on the top L/H side of the page. Basically it a list of every thread you have ever replied to, unless you do not have it turned on? Or go in there every so often and delete subscriptions.
No worries, we are all here, just ask.
#28
#29
