Hail and well met Washington chapter - Ford Truck Enthusiasts Forums
Washington Chapter Washington Chapter
Join Chapter, Leader: Yahiko
Old 09-16-2014, 02:08 PM
CharlaineC's Avatar
CharlaineC CharlaineC is offline
CharlaineC is starting off with a positive reputation.
Hail and well met all!!
My name is Charlaine. I'm from elk Washington and am now the proud owner of an 1969 f250 camper special. She has a 360 under the hood and I believe that she has the c6 tranny. She's rear wheel drive. No four wheeling.
She's in need of some work. Exhaust manifolds need new gaskets and bolts with a few that need to be removed with and extractor. The carb needs to be adjusted and I need to replace that icr. I also need to replace the tranny pan gasket as well as the oil pan gaskets. I'm thinking of replacing the head gaskets as well as the valve cover gaskets just to be safe. The p.o. Didn't take care of her at all. I'm also searching the pick in pulls for some of the smaller parts I need. I'm also going to build a custom center console to house my cb and the new radio. Once I get the engine work done I can then save up for the body work as I'm planing to have her body gone through and fixed up the. Fully painted To match her namesake "Pearl".
Old 09-16-2014, 03:52 PM
NorthwesternCowboy's Avatar
NorthwesternCowboy NorthwesternCowboy is offline
NorthwesternCowboy has a very good reputation on FTE.NorthwesternCowboy has a very good reputation on FTE.NorthwesternCowboy has a very good reputation on FTE.NorthwesternCowboy has a very good reputation on FTE.
Welcome to the party! Good luck with the repairs.
Old 09-17-2014, 08:15 PM
oddfordjunkie oddfordjunkie is offline
oddfordjunkie is gaining momentum as a positive member of FTE.
Hello!
I make a living pulling/selling junkyard parts, if you want to throw up the list of parts you're looking for I can either let you know where they are or pull them for you.
Would LOVE to see photos of the truck! We all like pictures.
Old 09-17-2014, 10:39 PM
CharlaineC's Avatar
I just found Pull n Save in spokane found a cpl of things i needed but i'm still looking for
  • e- break light bezal
  • dome light cover
  • wiper fluid res
  • drivers side western mirror
  • plate light assembly
  • owners book
  • ashtray light mount
  • original rear view mirror
  • a set of hubcaps
  • A decent set of headers
  • Spare tire mount and hold down.
Old 09-17-2014, 11:19 PM
Which styles of Rearview Mirror, Hubcaps and Spare Mount? There are multiple styles.
I find headers in junkyards but the only FE sets I've ever seen have been low quality junk and rusted up bad.
At least once a year I do a run over the mountain if you'd like me to pull parts we can discuss that through PMs.
Old 09-18-2014, 01:03 AM
CharlaineC's Avatar
The rear view mirror mount I have is a round dot with a ball coming off it.
The hubcaps I guess the dog bowl kind.
And I'm not sure as to the spare mount. I know it goes in the bed but I'm not sure if goes on the side of the aux tank bump or the passenger side.
Old 09-18-2014, 02:49 AM
Pictures, save a 1000 words, which is great if you're not fond of typing. haha
Seriously though if you can get photos up then it would make it a lot easier, and you'd being showing off more of your loved truck.
You want a factory spare mount or any In-Bed aftermarket spare mount? The aftermarket ones can be found pretty easy and had cheap both new and used.
Are you wanting a mount on the windshield type rearview or the style that screws to the sheet metal above the window?
Hubcaps are easy to get, huge year range on dog dish caps. Best bet is talk to one of the Processors at the JY and ask them to set a nice set aside for you for a couple $s in their pocket. Otherwise they usually destroy them as it's quicker to get them off just smacking them with a hammer, used to be a part of my job.
Your wiper fluid reservoir the Bag style or the Plastic container?
The mirror may prove kind of difficult as they usually get wasted by the trucks getting moved by forklifts at yards.
Old 09-19-2014, 02:04 PM
GruesomeJeans's Avatar
GruesomeJeans GruesomeJeans is offline
GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.
Welcome to the chapter! Sorry about the late intro, but I'm the chapter leader round here. Just not on a lot . Thats a pretty nice truck you got your hands on. This chapter isn't the busiest of them all but it's picked up quite a bit recently. Hope you enjoy your stay!
Old 09-21-2014, 01:56 AM
CharlaineC's Avatar
Oldford my wiper res is the white tank that mounts on the drivers side with the small black cap and the pump mounts on the bottom. I found I thing the original mirror and from what I can see I just need the connector part. as far at the factory mount i would like an original bed mount. I'm not sure of the hubcaps that went with my year of truck. Also can the original bottle jacks able to be found or should I just buy a newer one and have the c bracket made for it.
Old 09-21-2014, 03:48 AM
The jacks can be found.
As for the rest of it, I need pictures as just about every part you're looking for has multiple different styles in the 67-72 body style. Beyond that, it's 40+ years old and by the looks of the mis-matched mirrors and condition of the truck it's hard telling what else has been changed.
Old 09-21-2014, 05:00 AM
CharlaineC's Avatar
this is the mirror connector
washer res
in bed tire carrier
Under frame
Old 09-21-2014, 11:31 AM
YAY!
Now I don't have to worry about wasting my money buying the wrong parts.
Old 09-23-2014, 12:43 AM
Acquired the mirror mount piece but not happy with the condition so gonna see if I can get my hands on a better one.
Also, someone said that Oriellys sells factory reproduction mirrors and parts cheap. Guy paid around $40 a piece for Western style mirrors, just had to buy the mounts and heads separate.
Will keep hunting.
Old 09-24-2014, 05:32 PM
Found a truck with the Western mirrors, want me to pull the drivers side for you?
My cell is 425-320-6932 if you want to text or have me send pictures when I find stuff.
Old 03-04-2015, 03:13 AM
Sportster.Mark Sportster.Mark is offline
Sportster.Mark is gaining momentum as a positive member of FTE.
I don't think the in-bed tire carrier will work in your bed
Modification of 80's Ford combination Washer res and Coolant tank. to fit a bump. CharlaineC 1967 - 1972 F-100 & Larger F-Series Trucks 3 03-14-2015 08:07 PM
got board and buit an Analyzer CharlaineC 1967 - 1972 F-100 & Larger F-Series Trucks 13 11-04-2014 12:19 AM
Freshened up the cluster a wee bit CharlaineC 1967 - 1972 F-100 & Larger F-Series Trucks 46 10-30-2014 09:14 PM
Searching for this lens CharlaineC 1967 - 1972 F-100 & Larger F-Series Trucks 5 10-23-2014 03:38 PM
ok this has me confused can you help CharlaineC 1967 - 1972 F-100 & Larger F-Series Trucks 11 10-22-2014 09:29 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
