1966 F100 Steering Column Advice
Old 09-16-2014, 01:11 PM
thumper7741's Avatar
thumper7741
thumper7741 is offline
I have been searching high and low for a Manual shift tilt steering column for my restoration. I am a large guy and the Ginormous Stock wheel is a no go if at all possible just for rooms sake, any advice!!!!
Old 09-16-2014, 04:33 PM
jowilker's Avatar
jowilker
jowilker is offline
I expect that is gonna be as scarce as hens teeth. Tilt wheels were used in upgraded packages and I have only seen them with autos.
John
Old 09-16-2014, 08:34 PM
garbz2's Avatar
garbz2
garbz2 is offline
Exact fit. accepts a gm type steering wheel. AKA just about every aftermarket wheel made.
1953-79 Ford Half-Ton Truck Column Shift
http://www.ididitinc.com/retrofit-st...ruckFS_Retr-49
Garbz
Old 09-16-2014, 08:36 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Tilt steering wheel was first offered as an extra cost option for 1978 F100/350, Bronco & Econoline. It was not available with 3 speed manual, 4 speed manual & A/T only.
The problem with 1961/66's is, the cabs are tight, leg room can be wanting, the 3 spoke 17" or 4 spoke 18" steering wheels do not allow for much "belly" room.
Some members of this forum like garbz2 and Bill W don't have a problem, but if your over 6' feet tall & 200 lbs. that is the problem.
Plus the older you get, the tighter the cabs become, especially when "Arthur" arrives.
Old 09-28-2014, 08:35 AM
thumper7741
thanks for the info guys!
touchfordtruck
11-20-2016 12:10 PM
fordparts429
04-13-2011 10:32 AM
gt40racing
06-29-2010 07:47 AM
dylan1952
03-11-2006 06:26 AM
medicpg
09-30-2003 04:50 AM
Quick Reply: 1966 F100 Steering Column Advice
