Zf-5speed oil
on
I would not run 30 weight, I get your idea of the heavier fluid sticking around better but it would also slow down the syncro's you might get a grind on a down shift or up shift The tolerances of these things now are so tight, not like the old days were they built them sloppy, you can run em dry for a week and not have a problem, now that would destroy a trans, experimenting never hurts, as long as you dont push the over the line. Like the president, dont cross this line, OK dont cross this one. Now this one. What a joke.
Lol...
Maybe I got to run redline then...
Anyway my problems are currently related to synchronizer and lots of noise .And it got worse when I filled the zf with the ford recommended ATF oil . I was hoping something else might help till I rebuild. After reading lots of posts it appears people use 30 w and the amsoil with different result.... This surely can get confusing :-)
I am one of those who does not swear by the sychromesh. 4 quarts of 20$ a qt royal purple synchromesh in my ZF ran ridiculously hot, I highly doubt anyone has a trans temp gauge in their ZF but I decided to plumb on in, and seeing 260* on hard pulls blew me out of the water. I replaced it once thinking it was broken/misreading…it was not.
Ok thanks for the info so far.
I spend some time and went onto the zf webpage . Under downloads I pulled up the lube oil PDF and checked for the S5-42 transmission . The lubricant class comes up with 02B.
Further down in the document they list the vendors and they approved oil and the zf approval number.
According to this list, there are quiet a few 75w80 oils as well as the ATF approved.
Did anybody else looked at this before ?
Not sure how to get it linked through my phone,but the document is at www.zf.com/lubricants
Under manuals I downloaded the PDF te-ml 02 which is for light truck and commercial applications.
I emailed zf about what truck and transmission I have and they replied I can use any fluid listed in the lubricant list on the document for this transmission . There reply :" you can use any oil according to 02B / 02E / 02F / 02L "
^^^^^ Direct link - http://www.zf.com/media/media/en/doc...s/TE-ML_02.pdf . LOTS of products mentioned, but nothing specific about diesel application. Page 7 provides some good info about temperature ranges (Note: it's in degrees C). Most notably:
I also found these two:
http://www.zf.com/media/media/docume...nsmissions.pdf (for the S5-42)
http://www.zf.com/media/media/docume...nsmissions.pdf (for the S5-47)
They have specifics about running behind a diesel.
My own experience with Mobil 1 ATF has been less than stellar. Fine and smooth in warm weather, but, to use their term, "impaired" in cold. Next fill will be TranSynd, since it's mentioned in both the above documents, and from what I've read about its use in other manual trannies that take ATF like ours.
In moderate climate zones, shift quality of non-automated transmissions is impaired when using the lubrication classes 02B / 02H.
that said, please post how that TranSynd works out - i'm not opposed to swapping fluid and destroying the evidence before my dad's next visit if it means less wear and tear on my truck!
