Cam HELP!
Cam HELP!
Getting ready to rebuild 390 and was hoping to get some suggestions from you cam experts out there. I'm not an expert and need help picking out the right cam. I have a 69' f100 with 3.50 rear end and a c6 trans. Haven't picked out anything for my rebuild yet, but was thinking of going with rpm intake, 600 cfm carb, and would like to use the stock heads. I want decent fuel mileage and low end power. I drive this daily around town. I want it to throw me back in the seat from 0-40mph. If I give her hell, I want to break the tires loose with ease. Don't care about a obnoxious amount of horsepower or high top end speeds or times. Your help is greatly appreciated.
Dyno programs are only as reliable as the data. Desktop dyno makes a lot of assumptions. I only read the first page but it seems little has changed since the version I got a few years ago.
Engine analyzer pro is pretty close, but if you don't double check the numbers it is still easy to get bad output.
Look at the torque curve below 2000rpm on those graphs. It is flat. Doesn't work that way.
Edit:I read the rest of it, pretty much the same it was years ago, the base it starts from is fixed, so low rpm power is optimistic, this skews the numbers high throughout the rpm range. It is a useful tool, just know that it isn't a perfect tool.
I meant I read the first page of the thread. I finished the thread. The program makes some assumptions, which is why it doesn't cost a ton of cash.
It is good enough, but just know it is optimistic. If you buy a converter based on those numbers you probably won't be happy with the outcome.
I'm not sure and I'm up for suggestions. I know how to put a motor together, but not much about the specs to choose parts for the build (this is my first FE). I've always relied on others to help me choose and the machine shop to do the machining. I've only assembled 2 small blocks (both still run hard and have had no problems).
