73-79 DJM beams on a 68 with disc upgrade, right?
Old 09-15-2014, 12:36 PM
Uni Moe's Avatar
Uni Moe
Uni Moe is offline
I've started acquiring some parts for my 68. I've just got access to a 77 1/2 ton with discs and power steering. I think I read on here somewhere that if I convert to disc brakes then I should use the 73-79 DJM beams, not the 65-72. Is that correct?
Old 09-15-2014, 02:50 PM
instig8r63's Avatar
instig8r63
instig8r63 is online now
The DJM #DB3004-3 Dream beams are listed as fitting 68-79 F100/F150.
Old 09-15-2014, 03:29 PM
HIO Silver's Avatar
HIO Silver
HIO Silver is offline
I recall there are actually two PNs so yes... spec the beams according to the year of the spindles.
Old 09-15-2014, 03:40 PM
instig8r63's Avatar
instig8r63
The difference in the king pins from the 67-74 to the 75-79 1/2 ton is .0001 thickness and less than 1/10th of an inch in length. The DJM king pin hole diameter is a lot larger than .0001 thickness difference from any 1/2 ton king pin.
Old 09-15-2014, 09:41 PM
dwil's Avatar
dwil
dwil is offline
The shackles and hanger kit numbers are different too... that was a lesson learned.
By the way, I have a 73+ set of shackles and hangers with rear shocks.
ALMIOST New... mounted a time or two... never driven.
f100today
04-02-2016 08:09 PM
MartyTheOneManParty
18
11-07-2015 11:27 AM
taylorjgreen
03-28-2013 12:00 PM
jawilliams00721
01-18-2013 06:17 PM
zsir
01-07-2003 11:45 AM
Quick Reply: 73-79 DJM beams on a 68 with disc upgrade, right?
