Up pipes and Down pipes.
Need some help with the brain trust.
I know I need new up pipes, they are leaking bad. My problem is when the shop that installed my Down pipe they not only clamped it they welded them too. So I can't remove it or move it without cutting it off. Is my only choice now is to remove the transmission? Or either way the down pipe has to be removed to do the up pipes.
The transmission has to be removed to do the up pipes, you won't be getting the bolts out of the top without removing the trans, at least i couldn't and im a professional mechanic in a very well equipped shop. If your working with the up pipes either get the bellowed pipes from riff raff or put the bellows in yourself, i had a thread on bellowed up pipes you can search for. also there is no reason why that downpipe should have been welded, hopefully it didn't mess up the flange on the turbo outlet to bad.
You can absolutely do the up-pipes with the down pipe still in. That's how I did it. Bellowed up pipe thread
The links to what parts I used are in that thread.
If you are going to do diy bellowed up pipes it's probably best to pull the turbo. At least then it will be easy to mike sure you have them right before welding
