replacing fuel pump help
Old 09-15-2014, 02:06 PM
cookingguy's Avatar
cookingguy
cookingguy is offline
So I believe the fuel pump is gone out on my 06 today. I am looking to drop the tank since I have a service bed on my truck. I need advice on how to drop the tank and replace the pump and sender unit on this truck. I work on my old jeeps all the time but never done a pump befor. Also I have probably a little over half a tank of disel in it and no where to siphon all that into so I am looking to do this with the tank full
Old 09-15-2014, 02:16 PM
npccpartsman's Avatar
npccpartsman
npccpartsman is offline
The pump isn't in the tank it's under the drivers side door on the frame rail with the filter in it. No reason to drop the tank unless the fuel sending unit isn't working. Takes about 30 minutes to change the fuel pump. 3 bolts, 4 lines, and 2 electrical connectors.
Old 09-15-2014, 02:26 PM
cookingguy's Avatar
cookingguy
The sender went out about a month ago. So I do not have an in tank pump only the one on the frame rail?
Old 09-15-2014, 02:39 PM
william_04_x's Avatar
william_04_x
william_04_x is offline
The fuel pick up, and level sender are in the tank. The fuel pump(HFCM) is on the framerail, under the drivers seat.
Dropping a full tank isn't hard. I had to drop the 44gal tank on my Excursion when it was almost full. Just gotta go slow, find the balance point, and use a good floor jack and a length of 2x12 to support it.
Old 09-15-2014, 02:43 PM
cookingguy's Avatar
cookingguy
So how can I test the pump on the frame rail to make sure it's bad?
Old 09-15-2014, 02:49 PM
Money-Pit's Avatar
Money-Pit
Money-Pit is offline
1. listen for it to run...it will run about 20 seconds after you turn the key on.
2. check fuel pressure at fuel regulator with gauge.
What symptoms are you having, to make you think the fuel pump is bad?
Old 09-15-2014, 03:02 PM
cookingguy's Avatar
cookingguy
I went to costco today and when I came back out the truck hesitated to start but it did start. Then went to the post office and came out and went to start it and it will just crank but will not turn over. Seems like it's not getting fuel
Old 09-15-2014, 03:04 PM
cookingguy's Avatar
cookingguy
Since my sender is bad could it be my pickup tube has crapped out on me
Old 09-15-2014, 03:12 PM
Money-Pit's Avatar
Money-Pit
are you absolutely sure you have fuel in the tank?
if you have an android phone do a search for torque pro. You need some gauges to diagnose this. it is unlikely that your fuel pump has failed.
Old 09-15-2014, 03:18 PM
cookingguy's Avatar
cookingguy
I just filled up a couple days ago I andhave driven about 88 miles since then but iam going to put some disel in when iI get home. But ireally dondon't think that's it
Old 09-15-2014, 03:33 PM
dannyboy950's Avatar
dannyboy950
dannyboy950 is offline
There is way more than just fuel issues to keep a 6.0 from starting. The 6.0 is an electronically controled, hydraulicaly operated injection system. There is a tech folder that lists all the different tests to be done to properly diagnose your problem. To properly diagnose you will need a scanner or something that will read live data at the least.
Old 09-15-2014, 03:38 PM
fordf150guy's Avatar
fordf150guy
fordf150guy is offline
Does it fire up right away when cold? If it does I would start reading in the tech folder about hot start problems and how to go about diagnosing it.
Old 09-15-2014, 04:15 PM
BigGreenEx's Avatar
BigGreenEx
BigGreenEx is offline
Sounds just like my problem, ended up being a blown o-ring at the oil pump. Ran fine, shut off, wouldn't start back up.
Old 09-15-2014, 04:53 PM
69cj's Avatar
69cj
69cj is offline
Open the upper fuel filter cap and have some one turn on the key with you watching the filter housing. If fuel fills the housing your pump is working.
Old 09-16-2014, 09:58 AM
cookingguy's Avatar
cookingguy
So it appears to be a hot start problem. When I got home from running errands yesterday after it had been sitting for a few hours and I went to start it and it started right up no problems. So I drove it to a local shopshould have a ddiagnosis this morning.
Quick Reply: replacing fuel pump help
