Side Steps
Side Steps
Has anyone used these or something close? How far do they stick out from the side of the truck?
I have these on my '92 f-150 and initially I had the same concern. Mine do not stick out beyond the stock side view mirrors. In fact they are about 2" inboard from them. They work well.
[Edit] In looking at your truck these would be well inboard of your mirrors. I'll post a pic if you want.
That is correct. It took me less than an hour to put them in and I like their look and function.
There is a slight downside. During the winter they can become quite slick and icy from road splash/slush, but it knocks off readily.
I like them. They really help my wife get in/out of the truck on the rare occasion that she will "get into that beast".
Received 3,102 Likes
on
they are very tough on the body metal. if it is not perfect, they will rip out of the body and fall off. a much better step is the DeeZee tough step. slightly expensive at $266. but well worth it. they bolt to the frame and stick out just under the rocker panel.
i have had a set on my 88 for the past 26 years. they have been hit and bent under the truck by tree stumps, but bend rite back out where they are supposed to be with a bit of leverage.
click on this link to see them:Tough Step
I would absolutely have to agree though that something that attches to the frame would be tougher, but then drilling attachment holes into the frame weakens that also...true?
They will probably more for getting out than in, getting in is fine but getting out there's nothing to put weight on but the steering wheel or the fold done armrest, the steering wheel being the worst thing to have to put weight on and the armrest probably not much better. The truck sits factory as a 2 wheel drive so I'll probably step over them. Getting out wouldn't put very much on them beings I weight like 140.
As for the steps you linked to, I have seen HORRIBLE things those Carr steps to when bolted to sheet metal STAY AWAY from them
NotSoSporty98
01-18-2017 07:08 PM
jwstrand
03-08-2009 12:57 AM
