'66 3 piece drive shaft bearing sizing?
I have a '66 f100 step side long box 352 auto. It has the 3 piece drive shaft. I'm replacing the U Joints and want to do the drive shaft bearing at the same time. I'm ordering the parts from LMC truck. According to them, there's two drive shaft bearing sizes. One with ID of 1.378" and one with ID of 1.5478". Any idea how I check the ID of the bearing without removing the drive shaft. I can't get at it to measure it as there's shrouds around it that prevent me getting the vernier at it. The spline shaft on the back side measures 1.375". Should I assume that the bearing ID is the 1.378"? Any insight would be appreciated
D9TZ-4800-A .. Driveshaft Center Support Kit - Bearing is 1.37" / Available from Ford & auto parts stores.
1961/79 F100/250 with two piece driveshaft.
3) C5TZ-4635-F .. U-Joint (Spicer number: 210392-X), 2 cups are 1310's, 2 cups are 1330's / Obsolete - Available from auto parts stores.
1965/79 F100 & 1975/79 F150 with two piece driveshaft.
Why buy parts from LMC in KS and pay shipping charges when you can get them locally from NAPA & etc auto parts stores.
'74 Ford 250 CS
06-06-2018 11:22 AM
oldcoupe42
03-26-2004 03:32 PM
