Saving a 1982 F100 from being junked - Semi-Restore - pic heavy
From what I understand, my truck is completely all original. So that makes sense. My coworker said his dad got that truck with all the options they had...
This is partially true. It is the highest trim level, and does have things like A/C, Cruise Control, Two-Tone paint, Automatic Overdrive, etc.
However, it is missing options like the factory protection group, the security lock group, power windows and locks, and the factory clock.
My fix-up thread seems to be becoming a 'Should my truck have this hood ornament?' thread.. I mean this in the most nicest way possible (even though some will get upset).
But hey... I just bought a new chromed thermostat housing!
I took the intake and valve covers into work today and sandblasted them. I have a sandblast cabinet, but it's kinda small and doesn't fit those items. I am planning on powdercoating the valve covers high gloss blue and the intake chrome. I have a powder coating setup, but just using a regular oven for now. I've got those parts in the oven now gassing out to make sure all oil, etc is gone.
As far as performance, I'll probably change out a few things in the block.. Cam, rockers, valves, etc. Doesn't really need to, but I want this thing to run good. I've seen the 302 Engine rebuild kits for around $300 - $400 that has pretty much everything. I may go that route. Honestly, this is my first go around in ford engines. I've rebuilt my Land Rover Disco 2 engine and my V65 Magna engine so I've got a tiny hair of experience (NOT)..
I'd love to find a way to mount the alternator and power steering pump better (or at least make it look better. A different set of brackets for them would help, but I'd like to keep the belt configuration)... See the previous pics in this thread to see what I mean...
Any suggestions would be great!
You're not the only one. Many people have altered the brackets just like you plan for the same reasons.
There are plenty of options for alternator brackets. Some people make their own, or there are companies that make them for you.
For example:
Alternator Mounting Bracket - 289-302, 66-77 Ford Bronco, New - Toms Bronco Parts
I think the alternator pivot bolt goes through the cylinder head, so your configuration won't change.
I'm not entirely sure about the power steering pump bracket, but I'm sure they make those too. You might even end up getting away with brackets from a car, since they tend to have less room for enormous bracketry.
Also, did you know that 1980-1983 F100's came with two different lug patterns for the wheels? It would be important to know which one you have so that ordering brake parts will be less confusing at the parts counter. Judging by the pics, it looks like you have the larger 5x5.5 lug pattern shared with the F150 and Bronco. But it's good to double check.
For example:
For example:
Would that alternator bracket replace that hideous thing that is holding the alternator now? lol!
Welcome to FTE, Silar, and nice truck!
Here is how I re-mounted my alternator:
https://www.ford-trucks.com/forums/1...with-pics.html
Thanks again!
#28
I meant to take pics of the condition of the valve covers before, but you can see them in previous posts in this thread. They were pretty bad looking. Paint chipping, rust spots.. etc...
I've now sandblasted and powder coated them, and here they are! Way better looking! Of course a new breather and PCV grommet too!
I used Columbia Coatings - Super Mirror Blue. I really like this color...
#29
