Replaced #5 injector and it tossed a code after install.
Old 09-14-2014, 08:08 PM
Restlesswildman's Avatar
Restlesswildman
Restlesswildman is offline
As the title says.
Only code I had was P0603 before the injector was replaced.
After I had it all back together and started I had a P0205, P0603, P0670.
I resolved all of the codes. The P0205 and P0603 have not returned after an hour of driving. The P0670 was related to to my failure to get the glow plug harnesses fully plugged into place. Man those were a pain!
So why would I get a code for the #5 injector after putting a new one in at start up?
Old 09-14-2014, 08:50 PM
9228.bobcat's Avatar
9228.bobcat
9228.bobcat is offline
Did you clear it and try again
Old 09-14-2014, 10:22 PM
Restlesswildman
Cleared all the codes fixed the wiring issues and no codes.......wife took it out and beat on it after i did an hour in it....
I was just wondering if getting the injector code was normal or not...
Old 09-14-2014, 10:45 PM
Yahiko's Avatar
Yahiko
Yahiko is offline
I changed a bad glow plug and cleared the code. It came back.
Then the next day after an over night sit. It was gone and has
not come back. Got to think that the PCM has a hard time
forgetting things sometimes.
Sean
Old 09-15-2014, 05:03 PM
Restlesswildman
Well the only code that keeps popping up is P0275!
The truck runs smooth and does not have a noticeable miss like it did with the old injector. It is hard for me to believe I have valve damage or a dead hole as good as the truck runs.
I talked with Run6.0Run today for a bit! Thanks Anthony for the time, It is much appreciated!
I am going to do a bubble test tonight.
I am at a lose here and and beside myself!
Old 09-15-2014, 07:00 PM
Restlesswildman
Ok just finished up doing the bubble test and nothing at all.
So that would mean my injector seals are good.
Old 09-15-2014, 07:08 PM
Yahiko's Avatar
Yahiko
Yahiko is offline
For then that don't know a P0275 is a Cyl #5 contribution test/Balance issue.
Not sure what could be causing the issue. What did Anthony say?
How did the space around the valve springs look?
Sean
P.S. PM on the way check you mail.
Old 09-16-2014, 05:32 PM
Restlesswildman
I have not seen a DTC since yesterday. So I am hopeful that it was just a gremlin that is not an issue!
Old 09-16-2014, 07:12 PM
Yahiko's Avatar
Yahiko
Yahiko is offline
Good to here.
Sean
Old 09-23-2014, 07:23 PM
Restlesswildman
Update to this dilemma!!
I finally got my AE set up and going. I cleared everything possible on the truck and have been code free for 36 hours. The power Balance test shows all injectors are very close to each other. There are none dropping out and I have zero misfires.
I am hoping it is totally resolved but am not holding my breath.
I am leaning towards a possible ECU issue.
kt19
10-27-2014 05:37 PM
dt444e
09-27-2009 06:03 PM
DesertRat1
1997 - 2003 F150
04-21-2007 10:35 PM
seanlleiker
01-22-2007 09:34 AM
fordfast
03-16-2005 05:19 PM
Quick Reply: Replaced #5 injector and it tossed a code after install.
