My 88 has a white small hose that hangs down from the cluster I would like to hook it back up for the needle in the p/r/n/d.. what does it hook up too..?
If the loop is cut? That means it probably died from old age but it could be from the needle being gummed up. Wouldn't hurt to go a little deeper and clean stuff up. Be careful with the painted stuff!
Sounds like the cable is broke in the middle and you need one of these. Make sure it is for the correct transmission. The one pictured is for a C6 with no overdrive.
