Making your own lighted sun visors
Couldn't say the wife nor I'd care about a lighted mirror but it's gotta be worth it to someone for you to do this. Cool idea and congrats on the project. I take it you've done a snippit of interior work before and kinda know the road your heading down? Visors are pretty easy to do but if you can, use a sewing machine vs. a hand stick on these if you can......just easier though I've seen machine like stitching done by hand.
Nice work gm4walls! Cool project.
Awesome that you picked up the ball and ran with it. Looking good so far. Yes I have only seen one in real life, well 2 now with fordrealdrives pic.
And yes that visor is way thicker than a none visor one, but my dvrs side is just as thick and without a light.
Happy wife, happy life, more Ford truck parts.
I just checked one from a 79 super cab. Top to bottom 6 1/8 " ,finish to finish edges . I forgot i had a set of them until i started following this thread and i just bought a set of plan jane ones so i could have white ones . The ones i have are like the ones here on this thread ,not the blue ones. I could have changed the color , oh well maybe later.
#28
Okay, want some input here. Today at Home Depot, I looked at some materials for replacing the cards inside the visors. First thought was hardboard (Masonite). There are two thicknesses, 1/4 and 3/16. I have used this for door panels, but not for visors. You guys think that would be rigid enough for a visor that will be pulled up and down for years to come? Also, since the physical size is larger then the originals, I am thinking about making a lighted visor for both sides.
#30
I measured 6 1/8" also, top to bottom. Measuring from the "stub" =11" to the edge of the light/mirror unit, and the thickness is near an inch throughout the length of the visor...it does get thinner towards the stub, approximately 13/16".
It appears to be a hard plastic material under the vinyl/padding. The piece is plenty rigid yet lightweight. The hardboard or maybe some abs plastic should work.
This is definitely not my area of expertise, but I'm interested in seeing it come together.
