Rear Gear Change?
Old 08-01-2015, 09:48 AM
SweetBearCub's Avatar
SweetBearCub
SweetBearCub is offline
Originally Posted by jayro88
I wonder what kind of mileage/drive-ability you would see out of a ford diesel that was designed for the Econiline from the factory. Maybe a 7.3 Powerstroke or even a turbo 7.3 IDI. Both were offered as options for the Econoline and could provide fairly decent power/mileage (I have no idea about mileage for your setup, but on my NA IDI e250 I average 16-18 hwy.
For the record, I have a 2000 E-450 auto with the 7.3L turbo diesel, and a Blue Bird bus body, about 28 feet total length, 9'6" height. On the 2800 mile trip home, mountains included, at 55 give or take, I averaged 10.69 MPG.
Old 08-01-2015, 11:29 AM
jayro88's Avatar
jayro88
jayro88 is offline
Not bad going through the mountains. Could be in the 11.5-12.5 range on flatter ground. What rear gear do you have?
Old 08-01-2015, 12:38 PM
SweetBearCub
I'm not sure what rear end gear I have, is there a way to tell from my VIN? (1FDXE45F1YHB05790) EDIT: This forum apparently links VINs right to a decoder. Under the 'Equipment' tab for the VIN, it says my van/bus has a 4.56 axle ratio. I have no idea how accurate this information is.
As far as the high for my MPG on that trip, my notes show 12.19 MPG for the fill up in Sun Valley, AZ, coming from Tucumcari, NM, 408.5 miles on the trip odometer.
Old 08-01-2015, 10:26 PM
kountzecobra's Avatar
kountzecobra
kountzecobra is offline
From what I have learned, the E-450s and E-Super Duties all had rear gears in the 4.63 to 4.10 range. BTW, there should be a tag attached by the bolts on the rear end housing cover with the ratio.
Thanks for the replies.
Old 08-30-2015, 08:08 PM
E350John's Avatar
E350John
E350John is offline
Enlightened User
I run a 4.10 rear with truetrac locker and 35 spline axles on my 5.4 gaser, but I run 3" taller tires and it suites me just fine. I tow some heavy work trailers...
JB78f150
01-04-2012 12:21 AM
polacko
32
06-14-2010 08:00 AM
Ken Blythen
04-06-2008 01:32 AM
02f250fx4
1997 - 2003 F150
15
01-20-2008 10:11 PM
enoree
05-22-2006 12:28 PM
Quick Reply: Rear Gear Change?
