1979 Ford 400 Estimated Gas Milage Question
Hello all,
I have a 1979 Ford F150 Supercab with a longbed and I want to know what my estimated gas mileage will be after I insert a new motor into it. I plan on putting a 400 motor into this truck with an after market timing chain, intake, and carb. The truck also weighs close to 6,000lbs.
What do you think the estimated gas mileage will be after the new engine is put into the truck?
Thanks!
Thanks!
If you get 12mpg then it's time to have a party. I have owned two of the 79 super cabs and ran them for about 10 years , 9 t0 10 most of the time . I had another one , same size with the 460 and it got 9 to 12 , some times. I don't drive them hard , all highway ,freeway use and no hills hardly at all. Used in my construction co. for hauling tools most of the time. If you want fairly good MPGs get a small ranger , these big boxes were not built to run cheap.
justforkicks
18
05-01-2009 08:37 PM
