Towing problems
The OPs issue is either a simple electrical fix that can be fixed by checking for voltage at various spots in the truck or his truck was flashed incorrectly. Since the trailer simulator worked at the dealer and the trailer works connected to another Ford, I would start with the connection to the trailer. His pin could be dirty, bent, pushed in or something preventing a good electrical connection.
Brittany
I had a 2012 XL, no hitch, or trailer package of any kind.
I installed the Ford Brake Controller and added the wiring harness with the seven pin plug.
Dealer flashed the controller, and his machine showed everything was fine.
Hooked to trailer and 'no trailer attached"
Well there was a wire from the plug connection on the left front fender, that had the controller wire going that far, but was not there, to go on to the new harness in the rear.
Dealer Tech added the wire, and everything went as designed.
No one knows if the wire was supposed to be there or not, from the factory. Just my .02
MYTRUCKNOWRATTLES
6.7L Power Stroke Diesel
53
11-27-2013 08:50 AM
