Frame twists a lot on 96 F150
Yes and no. I had an '85 F-250 and even brand new I could easily get about 4" of misalignment in the body by getting it crossed up. That's crawling, not beating on it hard. So that's the "no".
The "yes" is that if you beat on a truck long enough the body mounts will start to fall apart and you might start to get cracks in the frame, and it will flex more as it gets "loosened up."
By the way, while my '85 F-250 probably had a stiffer frame than a '96 F-150, it also had less compliant suspension, so there was more torque being put on the frame when I crossed it up. So it's not necessarily clear which would flex more on the same terrain.
That is just normal
Frame flex on a C channel frame is common, our era trucks move no question to it. Watch a loaded semi take off watch the left side of the truck pick up they flex too, just not as much. Even the 04+ fully boxed frame 150s ride in one of them and watch the bed in the mirror they dance quite a bit. There has to be or if it is too stiff it will find weak points and there will be the start of the cracks.
Example; When I use to do my fleet repair on a lot of GM trucks(early 80s-mid 2000 trucks) the 88-98 were bad about cracking in the boxed areas under the cab. The frames under those trucks were kind of sad frames where the hitch mounts will deflect twist and before long your hitch is no longer straight its pointing down. Where the C narrows they will go to crap there and top of the bed and cab will touch, but that is like a rock .
Curtis
Curtis
jempaul
08-22-2015 12:45 PM
mando jake
02-26-2009 06:38 PM
