94 F150 A/C dash vents work intermittently
I'm trying to find out why my A/C vents work intermittently. I notice frequently I lose airflow from the dash vents to the floor vents. It seems it happens under engine load but not always. I tried trouble shooting the vacuum lines but none of the lines or tees were broken, disconnected or kinked. Also the compressor quit working while I was stuck in traffic. It came back to life after driving normal speeds for about 15 minutes.
I'm stumped.
I'm stumped.
I have this exact same problem. Started with my heater doing it and ac worked fine. Then ac started doing it. Been trying to figure it out for a while.
I've heard anything from check the vacuum at where the hoses connects to the firewall. To it's a bad control switch or cracked reservoir but no luck yet.
The only thing I couldn't check were where the two lines go into the plastic conduit. It's taped up. I was assuming those lines are in good shape since the other exposed lines are still good. My one suspicion is the plastic vacuum box attached to evaporator cover is leaking. It doesn't look like it's replaceable.
pcdocta
43
03-19-2017 04:16 PM
78bigunns
07-10-2011 09:28 PM
