Burnt old FICM ignition wires
I'm new to diesel engines and just learning these things after my purchase of a used 2004 F-250 6.0…
Got a question for all the 6.0 diesel tech gods on here (I say that with repeat, I know nothing about diesel engines).
So recently truck started running rough, got a code of P0265 (Cylndr 2 Injector Circuit High)…
Took it to a mechanic for a look see, they told me that the wiring that comes out of the FICM for ignition is in bad repair and cracked which is causing the problem.
They recommended a new harness for it.
I waited to do any repairs since I was potentially going to trade it in.
Next day I tried to start it but no-go, cranks but docent turn over, no smoke from exhaust either.
After reading some post here I realized that the FICM probably is the main culprit, and the harness needs to be replaced to get it back up and running.
Now main question…
After reading a very good post about the FICM and Fords Inductive heating by using higher volts, could this inductive heating have caused the wire harness to crack and deteriorate at a much faster rate than normal? Just wondering if the bad wire harness is a by product from the inductive heating or maybe something more going on in the electrical on that engine?
Thx
Ben
Now main question…
Thx
Ben
While the inductive heating does pull more current while it's heating, the truck is now 10 years old and the harness/FICM placement near the hot turbo (and rough handling during previous repairs) probably has as much or more to do with the deterioration as the FICM strategy.
Thanks
Thx
Does anyone know if this harness is just a matter of just disconnecting connectors and plugging in the new harness, or am I looking at doing soldering etc…as well???
