Looking to do high idle mod.
No biggie. Of course, make sure you tap a fused circuit that's only hot in "Run" to power the dash switch to the PCM input. Driving with the switch on doesn't do any harm. The 12V signal is only an enable command to the PCM, and the high idle event is initiated through software/programming. The PCM has to prove various conditions(speed=0, foot brake=off, trans not in any drive gear, etc) before idle speed is increased. Parking brake has no effect on mine.
on
When I had DP Tuner do my chip I had him put a high idle in the program, I dont need 6 settings, so I got 1 economy, 2 normal, 3 high Idle 1400 RPM's 4 50 HP 5 100HP and 6 150HP. Works awsome I love it, now I have to do the injectors, Smoke's like a coal train on 6, then I will have them reprogram it for me, A little smoke means buisness when you pull up to a cummins with stacks.
