Poulan chain saw runs fine for 30 sec to 1 minute, then dies
I have a chain saw I inherited from my uncle. I had to replace the primer ball and the fuel lines, as well as a diaphragm from the carb. It runs just fine for around 30 seconds to a minute, then dies like I shut it off, but I can see that it still has spark with an inline tester, and the primer bulb is still full of fuel. I am at a loss, and am looking for ideas how to get it to stay running. Pumping the primer bulb doesn't help either.
Carb looked clean. I got it going, mostly. Found that the fuel line that was actually the main supply line independent of the primer line was broken. Had to figure out where it went, then got it worked through. Ended up doing the same with the primer line as well. Still had the issue, so I had found some had to run the mixture screws in to clear the passage, then back them out. I suspect I need to turn the high speed screw a bit more, as it wavers at full throttle now.
This round I put Lucas in, I think. I started monkeying with it a month or so ago, and been a couple weeks just getting parts in. I only get a chance to get the parts picked up on weekends, so I would wait all week to get them. First was a primer bulb, then the carb kit. I know it was a synthetic that claimed to be good for multiple mix ratios. I mixed the gas about a month ago now...
I run the Lucas in most of my stuff, from chainsaws to dirtbikes to sleds and even my Lawn Boy.
Make sure the spark arrestor isn't gummed or plugged, it's the little screen in the muffler.
A popular trick from the Lawn Boy group is to bake the muffler on the grill for a while to dry out all the gum so it can be shaken out.
FordsOnlyGarage
11-17-2018 08:43 AM
cool 48
02-02-2008 12:15 PM
