2005 Navigator floor shifter help needed
Can anyone tell me how to adjust the shifter cable for this vehicle? It won't go into park properly and will not start. You can move the shift lever on the transmission by hand and it will start but once you move the floor shift lever in the car it won't go back into park. Is there something else I should be looking for? Thanks
Set the parking brake, then put both the shifter and tranny in neutral. Install the cable and it should be good to go. If need be, squeeze the tabs on the yellow adjustment block and move it accordingly.
imlowr2
01-01-2006 09:04 PM
dj9124
12-08-2003 08:32 AM
