Clutch is easy to jumper with a spare fuse if yours is the type up on a plastic rack by the pivot.
not sure what year they went to the switch on the master cylinder pushrod.
Its on the push rod under the dash. Someone told me that they loosen up. Don't know if it can be tightened but I really have to stomp that clutch to get it to start.
