2002 F250 5.4 Head Gasket Advise
I have looked through many posts, but must have missed something. I read that Cab removal is Necessary and that it is not. I Have a 2002 Regular Cab XL 4x4 F250 with the Gas 5.4L V8, I am 95% certain the head gasket has an external Coolant leak (I can see the coolant bubbling out passenger side where head mates to block).
I got the truck for free. Has 300k miles on it, but amazingly runs well, shifts smooth, everything works, but has the coolant leak and overheats every once in awhile.... I have above average mechanically ability, but not so much on this truck.... Basically if its "to much" effort to fix i am going to part it out... Any advise?
The cab isn't required to come off any year Super Duty, even the 2015s. There is a cab-on procedure to do everything up to and including an engine replacement. From 2008-present the shop manual states that it is "preferred" to remove the cab because it's quicker.
If you have access to a two-post lift you should remove the cab, it will make the job much easier. But it's completely possible with the cab on.
westkane
1999 to 2016 Super Duty
07-01-2013 05:10 PM
