Cooling system maintenace/upgrades
#31
#32
#33
Removing the stock mechanical fan can reduce rotational mass and free up some horsepower and torque. Previous independent test have shown some pretty nice increases. Our team would really like to explore the actual gains at some point in the future.
Thanks
#34
No thanks, the stock system works fine and the 6.0 is not lacking in the hp or torque dept. Like WatsonR said, the power for the fan has to come from somewhere and amps are in short supply on these trucks.
#35
#36
#37
I tried electric fans on my f150. Was a dual fan set-up, covered the entire radiator... they ran awesome. Gain of about 10hp, never ate themselves. The electronic/wiring were top notch... but it ate an alternator every year and each unit drew about 30 amps and in the summer ran continuously with A/C turned on. In the winter they ran when the defroster came on (A/C clutch engaged), so there was a constant draw on the battery... yep ate one every two years.
But for a measly 10hp, I'm not spending $400 to possible flow less air and have to replace alternators and batteries every year or so. That said, I wouldn't consider this an upgrade, cool to say you have electric fans, sure but it's cost prohibitive.
#38
#39
#40
#42
#43
Yea, it's not something I would be doing either. The factory fan flows a **** ton of air and works well. I would imagine a dual fan setup that flows a lot of air for our trucks would be very taxing on the alternator and batteries. Also, it's not that I wouldn't consider the Mishimoto radiator and "upgrade" per say as the factory radiator has no problem cooling the truck. The "upgrade" comes in the fact it's an all aluminum unit with no plastic end tanks. The thermostat though seems to be proven to be worth it. I'll get the Mishimoto radiator once my stock one craps out, but it was replaced around 70,000 miles when it was in an accident, so I doubt I'll be having to replace it any time soon.
#44
which would you rather have, two medium pizzas or one large .
This thing is big, lots of pitch on the blades, and can be driven faster than engine rpm when the PCM says it's needed. If you want to move a lot of air it's going to take a lot of power. I think this is an example of some of the good engineering on these trucks (except for the routing of the wires for the fan clutch). Replacing this with anything electrically driven I'm aware of would be a downgrade.
I do have the Mishimoto radiator and thermostat and I like both of them.
#45
