Best Oil to run in 07 6.0l with 68,000 miles
Old 09-12-2014, 03:48 PM
bismic's Avatar
bismic
bismic is online now
Received 2,483 Likes on 1,722 Posts
Originally Posted by BryanStein
Well, imagine that???? I wonder why. Yes, sarcasm.
Mark what was originally recommended?
Originally Ford stated (in the owners manual) that 15W40 was "preferred" above 30*F (and "could" be used down to 10*). 10W30 was "preferred" between -10* and 30*(and "could" be used from 30* to 90*). The manual also states that 15W40 is "required" for towing heavy loads above 50*F. 5W40 wasn't even mentioned in the original owners manuals.
Now, in their technical web site, Ford states that 5W40 is good for -20* to over 100*.
Clearly some people decide to make their own choices on oil instead of relying on Ford's published info. Roadrunner01 has chosen to use 10W30 at higher temps and while towing and it has given him very good UOA results.
Personally, I believe that different brands of oil behave a little differently from each other and it is hard to make blanket statements. As an example, Mobil 1 TDT has not sheared as much in my truck as Rotella T6 and Valvoline PBT. Mobil Delvac 1 ESP shears even less than the TDT.
Old 09-12-2014, 06:06 PM
69cj's Avatar
69cj
69cj is offline
I'm gonna go get a 12 pack. Let me know what the consensus is. Last thread like this I finished the 12 pack and many others before the thread mercifully died.
Old 09-12-2014, 07:58 PM
DomsF250's Avatar
DomsF250
DomsF250 is offline
This is the best idea I have heard all day
Old 09-13-2014, 12:04 AM
halltrash's Avatar
halltrash
halltrash is offline
wolfs head
put bullitprof deisel remote oil cooler on my 6.0 takes 23 quarts to fill system am otc about cangeing oil every 4,000 mi. or less started using wolfs head 15 40 semi sinthedic halve had grate results plus it`s alot less than rotila t
Old 09-13-2014, 12:12 AM
BryanStein's Avatar
BryanStein
BryanStein is offline
Quitter. You quit before the snake oil discussion started.
Old 09-15-2014, 02:58 PM
BoKnowsDiesel's Avatar
BoKnowsDiesel
BoKnowsDiesel is offline
Former Vendor
Originally Posted by Money-Pit
WHOA.....$52.36 a gallon?
Yes it is pricy, but when paired with a bypass filter, can run to 100k miles plus.
Old 09-15-2014, 03:09 PM
2006lariat's Avatar
2006lariat
2006lariat is offline
Are you implying that your oil will last 100,000 miles in a 6.0?
Old 09-16-2014, 07:01 AM
BoKnowsDiesel
Former Vendor
Yes. Yes I am.
Old 09-16-2014, 07:45 AM
69cj's Avatar
69cj
69cj is offline
Yes. Yes I am.
Dam, I must have drank that 12 pack too fast. I thought he said /\ /\ /\.
Old 09-16-2014, 08:08 AM
Per4mance's Avatar
Per4mance
Per4mance is offline
Ok......I'm gonna say it, Bo you don't know 6.0 diesel.........and that's all I'm gonna say about that!
Old 09-16-2014, 08:13 AM
BryanStein's Avatar
BryanStein
Well at least you didnt quit before a similar discussion started.
Old 09-16-2014, 01:34 PM
BoKnowsDiesel
Former Vendor
The reason that the 6.0's eat through oil so much is obviously because of the high pressure oil system. Our oil is a group 4 PAO base stock oil. We are one of only a couple companies in North America using a group 4 as opposed to group 3. It is extremely sheer resistant to hold up in the 6.0. The oil also has a 14 TBN for extended drains. It was tested on an oil rig, on one of the pumps I believe, and was ran for 100,000 hours (I will let you do the math figuring that to miles). After the 100,000 hours oxidation and viscosity were still within spec. I obviously can't guarantee 100k drain intervals, but if your analysis' are coming back good, we have had customers go there and beyond. We got our start working with the 6.0's in 2005, so this animal isn't anything new to us
  #28
Old 09-16-2014, 01:36 PM
BoKnowsDiesel
Former Vendor
I understand our claims are hard to swallow, and quite frankly most guys just are not comfortable leaving an oil in that long. It's not for everyone, but might be valuable for someone to do their own research and look into
  #29
Old 09-16-2014, 02:11 PM
Per4mance's Avatar
Per4mance
I'll tell ya what I'm gonna do, I have a healthy 6.0 with 92000 on the clock. Ill use my truck as a ginnie pig if your company pays for the damage from not changing the oil. Ill change the filters every 5000 miles and add a quart and do a oil sample test that you guys pay for, other wise I call bulls**t
  #30
Old 09-16-2014, 07:49 PM
Per4mance's Avatar
Per4mance
No response? I didn't think so
Quick Reply: Best Oil to run in 07 6.0l with 68,000 miles
