Hellwig sway bar and airbags
Old 09-11-2014, 05:05 PM
Kpt3's Avatar
Kpt3
Kpt3 is offline
I have airbags on my F250 and want to install a hellwig rear sway bar. Does anyone know if this can be done or if the airbags will cause a problem with installation of the sway bar.
Thanks
Old 09-11-2014, 05:57 PM
sdetweil's Avatar
sdetweil
sdetweil is offline
Thanks
can be done.. I did it that way.. airbags first.
the drivers side chassis bolt for the upper end link is a PITA .. others say to drop the spare.. was still hard for me..
Old 09-11-2014, 06:04 PM
Kpt3's Avatar
Kpt3
Kpt3 is offline
Thanks Sam
Old 09-11-2014, 06:06 PM
sdetweil's Avatar
sdetweil
sdetweil is offline
Thanks Sam
I would do that bolt first.. after that its a breeze. well wrangling the bar over the axle is 'fun' by yourself.
Old 09-17-2014, 09:55 PM
Kpt3's Avatar
Kpt3
Kpt3 is offline
Finished the install land yes the drivers side was a PITA. Test drove after install and can't believe how much better the truck feels planted to the road.
Old 09-18-2014, 08:15 AM
jdadamsjr's Avatar
jdadamsjr
jdadamsjr is offline
I had ford add a rear sway bar @ purchase time so I don't know the difference it makes on this, but they made my excursions sports cars
then had camping world install my airlift bags and wirelessONE remote compressor for $39 "I am averse to werk"
Old 09-18-2014, 08:19 AM
sdetweil's Avatar
sdetweil
sdetweil is offline
which bar link hole did you set it to?
Old 09-21-2014, 07:34 PM
Kpt3's Avatar
Kpt3
Kpt3 is offline
I used the center (second) hole.
Old 10-15-2014, 05:22 PM
sawtooth's Avatar
sawtooth
sawtooth is offline
Thanks
I have this exact setup. It's Awesome!
Old 10-16-2014, 07:14 AM
mmm635's Avatar
mmm635
mmm635 is offline
I have been very busy and not had a chance to raise my truck up from the rear and take a pic. That said, does it look like your rear passenger side shock absorber is hitting the sway bar? A few people that have done this install are getting this problem. I am.
You will see rub marks on the shock if it is happening.
Old 10-18-2014, 08:58 PM
Kpt3's Avatar
Kpt3
Kpt3 is offline
Checked mine this evening and there's plenty of clearance.
drz400dp
Ford Truck Parts for Sale
10-18-2015 08:06 PM
timf150
05-01-2012 11:13 AM
bobbyrjw
04-27-2011 11:43 PM
k150
1997 - 2003 F150
12-12-2006 08:12 PM
claymac69
07-21-2000 11:08 AM
Quick Reply: Hellwig sway bar and airbags
