another crank no statrt
2005 F350 with a crank no start.
During cranking The ICP volts correspond with the rise in pressure then the psi jumps from 500-700 to 8000, 10000+psi and does not start. It blows black smoke and sputters like it is gonna catch but doesn't. Does not start with ICP unplugged either>
FICM Main 48.5 KOEO 48 during cranking. Logic and vehicle are both at 11.5 and go as low as 10.5 during long cranks.
IPR 14.84 KOEO and goes to 48% during cranking
EPB volts are .96
FICM sync YES
CKP/CAM sync YES
MAP 101
BARO 100.76
fuel pressure at 62-64 psi KOEO and during cranking.
OEM fuel/Oil filter (Motorcraft) and motorcraft 15W-40 oil.
HPOP verified to put out 4000+psi and HPOP system air checked and no leaks present. Updated STC, dummy, standpipe.
Basically don't know why this truck won't start?
Only DTC is for glow plugs and a randon B1352-20 and B1360-20 both have to deal with an ignition key in circuit fault
EPB volts are .96
FICM sync YES
CKP/CAM sync YES
MAP 101
BARO 100.76
IPR is motorcraft
I thought so too but IPR is brand new Motorocraft. What do you mean by block oil passage thought. Blocked where in the system?
took IPR out
Took IPR out and it had some stuff on it. Cleaned screen and reinstalled, also pressed plunger and blew out valve with brake cleaner and compressed air. reinstalled IPR valve and cranked her up and is at 52% duty cycle. I also checked voltage at the IPR connector KOEO and got battery volts 12.9 is that right?
A ton of work
Recently done injector and oil cooler and EGR delete. I filled the reservoir for the oil cooler after installing the screen. I seem to be getting everything i need to start just not starting. Before all the work was done it never blew smoke just cranked and cranked, nw it blows smoke and intermittently tries to fire while cranking.
I've done a lil playing with testing early pumps. I found out a regular air coupler, coupled to the IPR test fitting and plugged off, explodes and flies across the shop!! Lol. And I had a 4000 psi mechanical gauge threaded into the stand pipe,, (I was making tools that day) and it pegged the gauge and blew a hole in it n shot oil across the shop. If the HPO system is dead headed tight,,, you will notice the starter really strain trying to pump up against a wall. Just some thoughts.
I've done a lil playing with testing early pumps. I found out a regular air coupler, coupled to the IPR test fitting,, explodes and flies across the shop!! Lol. And I had a 4000 psi mechanical gauge threaded into the stand pipe,, (I was making tools that day) and it pegged the gauge and blew a hole in it n shot oil across the shop. If the HPO system is dead headed tight,,, you will notice the starter really strain trying to pump up against a wall. Just some thoughts.
There is nothing that tell me this thing shouldn't start except for the random B1352 and B1360 codes but I've been told those wouldn't cause a no start.
Starting to think it's PCM but it passes the KOEO PCM check and I've reset all PCM adaptations so it wouldn't duplicate any issue it previously saw
Yup, once the system is maxed out with ICP pressure there is a noticeable change is starter/engine cranking. I think the HPO system is tight and makes plenty of pressure. Injectors are new and passes injector test, did bottom o-ring leak check, and bubble test and they all passed.
If its sputtering,, it's gotta be a fuel issue. Did a line get bent or crushed? Maybe something is clogging the banjos or in the upper fuel housing. I'd pop off the pass banjo and make sure fuel is flowing koeo. How did the filters look when it came in? You could pull the ebp sensor n throw shop air and listen at the tailpipe.
I had a truck like this the other day. Was working on it for a buddy. Truck wouldn't crank or anything. Starter was bad. Put a new starter in. It would crank and everything needed to start was achieved but it wouldn't start. I told the owner and he was like yeah it does that, hit it with some ether. I tried explaining to him it was a bad idea and waited till he arrived and let him do it. It fired right up. He says his truck will not start after sitting for a while, like weeks at a time, with out ether. I would not advised this at all. Just sharing my experience. I would think it would have to be something fuel related.
