Started my roll on paint job
Old 09-11-2014, 05:51 PM
LeoJr's Avatar
LeoJr
LeoJr is offline
Will a palm random action sander work or do you need something special for paint work? I've got a white fiberglass bed cover that needs some attention.
Old 09-11-2014, 05:53 PM
krooser's Avatar
krooser
krooser is offline
I have used kirker paint for 15 years when I spray. My Pete looked good for seven years despite my professional painter friends who poo-pooed the idea of using a low cost paint.
I shot the Pete with $350.00 worth of primer, reducer and color (single stage urethane).
www.smartshoppersinc.com
krooser's Avatar
krooser
krooser is offline
double post
Old 09-11-2014, 06:17 PM
cherrybomb37's Avatar
cherrybomb37
cherrybomb37 is offline
Equipment paint would work good too just make sure to use a hardener. Otherwise the paint never dries and it is soft. I painted a liquid manure spreader years ago just slapped straight john deere enamel on it and 2 seasons later I was back to a rusty tank. To remove the old paint I used a flap disc sander but you have to be careful I made a hot spot in the metal on one side and it's still showing threw the paint and primer.
Old 09-11-2014, 06:59 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
Originally Posted by irhunter
I hope to do a 20-foot paint job on my F350. I'm looking for durable and rust-resistant. I'm thinking about tractor/implement paint. I will, however, shoot it.
Roy
Nothing wrong with that, but I would clear it too so the shine will last. Single stage paint loves to fade out
Old 09-11-2014, 07:08 PM
dustyroad's Avatar
dustyroad
dustyroad is offline
love these diy paint jobs. subscribing to watch for final product.
I plan on doing it to mine "soon" using majic from tractor supply
Old 09-11-2014, 07:18 PM
thethrill's Avatar
thethrill
thethrill is offline
Looks good for what it is. Eager to see final product.
irhunter's Avatar
irhunter
irhunter is offline
Ha. I am considering tracking down some flat additive. I actually like the Arizona-oxidized look.
Old 09-11-2014, 07:23 PM
irhunter's Avatar
irhunter
irhunter is offline
Is the white due to paint, or the fiberglass gelcoat?
If it's paint, you probably have peeling clear coat. Once the clear is gone, your sander should be fine.
Same goes if you are going to paint a gelcoat.
Roy
Old 09-11-2014, 07:27 PM
Stevaroo01's Avatar
Stevaroo01
Stevaroo01 is offline
Does rolling the paint leave a texture like it does when you roll a wall? What kind of rollers are you using? Looks good in the pics anyway!
Old 09-11-2014, 07:38 PM
Diesel_Brad
Yes, that is why you have to thin it and wetland between coats
Old 09-11-2014, 11:34 PM
fordboy97's Avatar
fordboy97
fordboy97 is offline
Sub'd! Its looking good can't wait to see the finished pics
Tanner
  #28
Old 09-12-2014, 04:03 AM
krooser's Avatar
krooser
krooser is offline
For best results use a foam roller… I like a Sata roller
  #29
Old 09-12-2014, 07:25 AM
cherrybomb37
This is the final coat dry. It looks very nice, still gona be a 10 foot paint job its not perfect but overall im very pleased with my $22 investment. Clear coat tonight and ill 1500 grit wet sand then buff. Ill post pictures of that as well.
These are the supplies i used with a high density roller. I got good at mixing without measuring every coat has been flawless. The cab i am going to prime with rustoleum red auto primer then use Rustoleum Regal Red in a spray can then clear coat and 1500 grit wet sand and buff.
I just got RUST FREE doors and fenders from a co worker yesterday too, all it cost me was his lunch at the local bar! And up here in MN thats better than solid gold! So next ill be sanding down the doors, fenders and the two trim pieces for the front clip. The cab needs some patch work but i have a wire feed and access to as much scrap sheet metal as i need!
  #30
Old 09-12-2014, 09:59 AM
LeoJr's Avatar
LeoJr
LeoJr is offline
Roy
Yes, the clear is peeling off what the white paint. I'll need to get the clear off first. Thanks!
Quick Reply: Started my roll on paint job
