Yes. But it was Bowtieman55 that said his 85 has the 80/84-style reservoir. That's what I was addressing, and guessing that some of the early 85's got the early-style reservoir.
The lid on mine does not look like that. I'm guessing that's the 80-84 style. My 86 looks like LMC's illlustration:
Early (80-84) version on top and 85-86 version on the bottom. (We will park the discussion of how sharp the cutoff of 84 vs 85 is for the moment. I'm really curious to see what bowtieman55 says his truck's build date is.)
Not as early as I'd expected. And, you are pretty sure it is an original reservoir?
I didn't know the truck prior to buying it this year, but it looks to be original. Without sounding like a smarta55, it matches up to the truck perfectly; condition, wear, etc.
The only thing I find odd is the hose. The ones I've seen for the 80-84 reservoirs have a 90 degree fitting where the hose goes into the notch on the reservoir. Yours didn't look like it had one, but maybe so? Or the hose might have been replaced by itself as they tend to get soft.
Yep, that's what you need. It keeps the hose where it should be - sorta. But, if you are at the salvage why not get the later version reservoir, hoses (radiator and washer), and the bracket that bolts to the fender. That makes it a bolt-in to any of these trucks with a gas engine.
Low-budget build
BUT, it has crossed my mind. I've already upgraded to an '89-ish battery tray setup.
