Aftermarket Oil Gauge
Hey folks,
Just looking for some suggestions. Here's what I got done and what I want to do. I converted the oil sending unit over to an early model Mustang oil sending unit and got the interior factory gauge cluster working properly with the conversion....
Recently, I added a tree to the A-pillar and decided I wanted an aftermarket oil pressure gauge to go with it. The oil gauge I purchased came with another sending unit and a complete wiring harness.
MY question is: Should I add a T-Fitting into the all ready extended plumbing from the real oil pressure gauge conversion? Is there another location on a small block 302 to fit a 2nd oil sending unit? I also have a thermostatic oil filter adapter plate that only has lines for the engine oil cooler. What should I do? The area for were the original oil sending unit is all ready over crowded as is...
GlowShift | MaxTow Double Vision Oil Pressure Gauge with Electronic Temperature Sensor
This is the manifold I made to hook everything up.
Added a mechanical gauge later. Read all about it here.
https://www.ford-trucks.com/forums/1...em-gauges.html
Rovernut
03-07-2013 11:55 AM
williamsportwrestler
03-07-2011 07:03 PM
