Can I put a Touch Screen Radio in place of the Factor one?
I just picked up a 2008 Ford Edge SE with 104K. Everything seems great but I would like to install a Factor touch screen radio. What all is involved with installing one if I even can? What kind of mpg are most people getting with their edge with 100K or more. Is there anything I should check on the vehicle?
Thanks
GITanker
Thanks
GITanker
member with a 07 edge sel +
Installed my 7" android unit.perfect .plug and play ,3plugs plug rite in ,no wireing. Exact fit .factory subwoofer amp may need a resister installed in between pwr wire if you get a pop when rear amp turns on.I just unplugged plug till I solder in the resisteror in between power wire .all 4 door speakers work fine.
EPDP99
18
05-13-2006 09:05 PM
Coneynew
06-01-2003 02:31 PM
